Supra N_A Posted December 22, 2011 Share Posted December 22, 2011 is it just the 2 screws holding the cover on or is it in the inside the boot?? just want to replace the OEM with some led white lights... Quote Link to comment Share on other sites More sharing options...
Lbm Posted December 22, 2011 Share Posted December 22, 2011 Just the 2 screws iirc Quote Link to comment Share on other sites More sharing options...
Westy Posted December 22, 2011 Share Posted December 22, 2011 Less than 5 minutes to change the pair mate...two screws, cover, bulb change and reverse the process. Job done. Quote Link to comment Share on other sites More sharing options...
Littler Posted December 22, 2011 Share Posted December 22, 2011 Quote Link to comment Share on other sites More sharing options...
Guest rwd Posted December 23, 2011 Share Posted December 23, 2011 as above, just the screws, be careful not to snap the wire clips though Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted December 31, 2011 Share Posted December 31, 2011 old thread i know but ive done this using LEDs and not cheep ones and no matter what i do they start to flicker and then die (usualy they last 4 months tops) has any one else had this? im honestly thinking about going back to normal bulbs! Quote Link to comment Share on other sites More sharing options...
dan294 Posted December 31, 2011 Share Posted December 31, 2011 Same has just started happening to the Mrs' Audi, rather annoying on a Canbus system where you constantly get "Bulb Failure" warnings beeping at you on the dash! I seem to go through LED sidelights quite fast, number plate ones have been fine for 6+ months so far. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted January 3, 2012 Share Posted January 3, 2012 bump any one? Quote Link to comment Share on other sites More sharing options...
imi Posted January 4, 2012 Share Posted January 4, 2012 I reverted back to normal bulbs. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 30, 2012 Share Posted January 30, 2012 old thread i know but ive done this using LEDs and not cheep ones and no matter what i do they start to flicker and then die (usualy they last 4 months tops) has any one else had this? im honestly thinking about going back to normal bulbs! When converting to LEDs, you may have to put a resistor in the mix, as the power going to the LED may be too strong, and shortening the life of the LED. I had to do that with my Prelude, but I would've thought LEDs these days are 'pre-resisted'. I'm going to give the LEDs a go anyway. Quote Link to comment Share on other sites More sharing options...
