SPG Posted December 22, 2011 Share Posted December 22, 2011 Hi guys, does anyone have either New or Lightly used Spark Plugs for the N/A. Also looking to buy a starter motor. New Sparks would be prefered and a used Starter and Idler Pulley is what i am expecting . Cheers Link to comment Share on other sites More sharing options...
Dnk Posted December 22, 2011 Share Posted December 22, 2011 http://www.sparkplugs.co.uk try keron (trader) for a starter motor Link to comment Share on other sites More sharing options...
SPG Posted December 22, 2011 Author Share Posted December 22, 2011 Cheers Dunk, I will pm Keron. Any idea which plugs i should be looking for the N/A Link to comment Share on other sites More sharing options...
Dnk Posted December 22, 2011 Share Posted December 22, 2011 Depends how often you want to change them and how much you want to spend I'd go for platinum or iridium, if you check the FAQ section theres a lot of usefull info in there on plugs etc Normally Aspirated NGK - Standard - BKR5ES-11 (2382) - gap is already 1.1mm at the "-11" signifies they should be set to this already. NGK - V-Power - BKR5EYA-11 (2526) - gap is already 1.1mm at the "-11" signifies they should be set to this already. NGK - G-Power Platinum - BKR5EGP (7090) - gap to 1.1mm NGK -Laser Platinum - BKR5EP-11 (3440) - gap is already 1.1mm at the "-11" signifies they should be set to this already. NGK -OE Laser Iridium - IFR5T11 (4996) - gap is already 1.1mm at the "-11" signifies they should be set to this already. NGK - Iridium IX - BKR5EIX-11 (5464) - gap is already 1.1mm at the "-11" signifies they should be set to this already. Denso Platinum - PK16R11 - gap to 1.1 (but always check first) Link to comment Share on other sites More sharing options...
Dazzi Posted December 22, 2011 Share Posted December 22, 2011 I got a starter, needs a refurb though. You can buy the kit for about a tenner. Link to comment Share on other sites More sharing options...
SPG Posted December 26, 2011 Author Share Posted December 26, 2011 Parts found cheers Link to comment Share on other sites More sharing options...
