Iky Posted December 22, 2011 Share Posted December 22, 2011 As above, Im after the connector which plugs into the back of the heated seat switch, ideally with a few cm's of wire to join up the connectons. Thanks in advance, Iky. Link to comment Share on other sites More sharing options...
Iky Posted January 4, 2012 Author Share Posted January 4, 2012 Still need this. Link to comment Share on other sites More sharing options...
Iky Posted January 24, 2012 Author Share Posted January 24, 2012 Bump Link to comment Share on other sites More sharing options...
Iky Posted February 1, 2012 Author Share Posted February 1, 2012 OK, Some photos of the rear of the switch which i need a connector for, in the hope that there may be another connector off one of the other looms that may fit. Link to comment Share on other sites More sharing options...
barneybrendan Posted February 1, 2012 Share Posted February 1, 2012 pics not working for me Link to comment Share on other sites More sharing options...
Iky Posted February 1, 2012 Author Share Posted February 1, 2012 pics not working for me Should be fixed now. Link to comment Share on other sites More sharing options...
Iky Posted February 1, 2012 Author Share Posted February 1, 2012 Also if someone has a part number for the connector/loom, that would be great. Link to comment Share on other sites More sharing options...
Iky Posted February 8, 2012 Author Share Posted February 8, 2012 For anyone else in the same predicament, I got hold of the partnumbers - Quantity 1: 90980-10933 "HOUSING, CONNECTOR 6 PIN" Quantity 6: 82998-12440 "TERMINAL, FEMALE" The terminals seem to be the ones for coil pack connectors but with a little modification they will fit fine. Connector was around a fiver, the terminals were around the same EACH! so cost about £40 all in. Link to comment Share on other sites More sharing options...
Iky Posted February 8, 2012 Author Share Posted February 8, 2012 Some more info usefull for retrofitting heated seats. The OEM seat heater switch is just a push-on push-off switch. The OEM switch just connects a common lead (power) to an output lead (the heater or heater relay) and lights up the internal LED. There are 2 output leads and 2 LEDs (normally for left and right seats). Here are the pinouts for the switch: 1: ground 2: power to LH seat heater (when button pressed) 3: illumination negative 4: main power in 5: illumination power 6: power to RH seat heater (when button pressed) For the "illumination negative" wire, it's best to run this to a similar wire, like the one on the cigarette lighter. This is not a true ground...it is controlled by the dash-light dimmer knob so that the switch backlight will dim with the rest of the dash lights. Link to comment Share on other sites More sharing options...
