natony Posted December 21, 2011 Share Posted December 21, 2011 I've just bought a set of 19" wheels but i can't find a definite answer to what size tyres i need. The front wheels are : 8.5" wide with a 35 offset and the rears are: 9.5 with a 40 offset any help would be much appreciated Link to comment Share on other sites More sharing options...
Josh Posted December 21, 2011 Share Posted December 21, 2011 Rim width---Min tyre width----Ideal tyre width-------Max tyre width 7.0 inches-----195 mm--------205 or 215 mm-----------225 mm 7.5 inches-----205 mm--------215 or 225 mm-----------235 mm 8.0 inches-----215 mm--------225 or 235 mm-----------245 mm 8.5 inches-----225 mm--------235 or 245 mm-----------255 mm 9,0 inches-----235 mm--------245 or 255 mm-----------265 mm 9.5 inches-----245 mm--------255 or 265 mm-----------275 mm 10.0 inches----255 mm--------265 or 275 mm-----------285 mm 10.5 inches----265 mm--------275 or 285 mm-----------295 mm 11.0 inches----275 mm--------285 or 295 mm-----------305 mm 11.5 inches----285 mm--------295 or 305 mm-----------315 mm 12.0 inches----295 mm--------305 or 315 mm-----------325 mm 12.5 inches----305 mm--------315 or 325 mm-----------335 mm Link to comment Share on other sites More sharing options...
merckx Posted December 21, 2011 Share Posted December 21, 2011 I have the following which are close to the stock diameters which you always try to achieve. Front 19 x 8.5 +39 offset , 245/35 Rear 19 x 9.5 +37 offset, 275/30 Link to comment Share on other sites More sharing options...
Scooter Posted December 21, 2011 Share Posted December 21, 2011 pretty sure the set i have is 235/35/19 and 265/30/19 235/45/17 255/40/17 is stock if keeping the approx same widths then you can make a basic -5 on the profiles as you go to 18" diamter and then -5 again to 19" eg 235-245/40/18 265-275/35/18 235-245/35/19 265-275/30/19 Link to comment Share on other sites More sharing options...
natony Posted December 23, 2011 Author Share Posted December 23, 2011 Thanks guys, im going to go with 235/35/19's in the front and 265/30/19's in the rear Link to comment Share on other sites More sharing options...
