Electricians?
b_have
Hi all, I'm fitting a 2KW inverter into my mobile workshop (karting) and need to run a cable from the 110ah leisure battery to the inverter. Can I use cooker type cable to connect or what would you recommend? (will only be running power tools and 1kw kettle from the inverter).
If it's all inside, you'll get away with some 6mm twin n skin (cooker type cable) most diy places will have it.
If your routing it outside, you'll either need to put it in a conduit or use a SWA cable, 6mm again, 3 core (2 cores and an earth)
you might get away with 2.5 or 4mm but you shouldn't use power tools and boil the kettle at the same time.
H'n'S
Adam
