antno Posted December 20, 2011 Share Posted December 20, 2011 just wondering if anyone has seen a switch like this into a f con? does anyone know what this port is for? i thought you could link your computer via this port if you made a cable. not messed about with the switch too much as the cars been off the road. switch just says trig on it cheers antno Quote Link to comment Share on other sites More sharing options...
Nic Posted December 21, 2011 Share Posted December 21, 2011 Only an HKS Pro Dealer has the software to be able to view and modify the F-Con. Is the switch connected to the F-Con? Quote Link to comment Share on other sites More sharing options...
mark newman Posted December 21, 2011 Share Posted December 21, 2011 Ryan can do it for you Quote Link to comment Share on other sites More sharing options...
antno Posted December 21, 2011 Author Share Posted December 21, 2011 (edited) Ye the switch is connected to the f-con. Ye I think you have to be a hks pro writer to acess this one as it's just the f con and not the f con pro. You can get the software online to crack the pro and adjust the settings. Just need to make the cable. I'm just wondering about the switch really, just if anyone has seen one similar before. The ecu doesn't have anti lag function or launch control I don't think as it is just a piggy back fuel and ignition, so I don't think the switch is for that Cheers antno Edited December 21, 2011 by antno (see edit history) Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 21, 2011 Share Posted December 21, 2011 i was doing a little bit research for you - some forums were saying the switch is something to do with adding more fuel etc Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 21, 2011 Share Posted December 21, 2011 http://www.supramania.com/forums/archive/index.php/t-87771.html Quote Link to comment Share on other sites More sharing options...
