hi from france
Guest One-T
hi all
i'm jonathan and i have 22years
i live in france
i bought a jdm supra tt 6 last year , bpu (1b , but i have too many problems on 1.2b)
in the futur , i would like to built single ( env 750hp) =D
the engine is rebuilt with oem piston because a bad spark destroy one piston :(
my car
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/310392_104343983010636_100003051050144_34666_1144464938_n.jpg
and the problem on 1,2b
first pass
second ( impossible)
third ( impossible)
result , 318HP
and my config
mod ettc
stock bloc
inox exhaust ( like trd) and full decat ( no restrictor)
fmic
hks ssqv
bcc , sld
avcr, tt hks type 1
supersparks
walbro 255l mod 12v
ngk 3330
thanks
bye
Edited by One-T (see edit history)
this is a old pics ,
it's fully registered to france ;)
i post other recent pics tomorrow
many supras keep uk plates because the registration is more and more strict , even more for jdm supras
Yeahhh good pronciation :) . Sorry for my english, it's too basic ^^
It's a baltic blue , oem color ;) Many people dislike them . I'm love it
My problem isn't resolved ... Nobody find where is my probleme =\ . too rich.. Too poor . Bad turbos .. No idea , i not have afr However it's highly recommended ( this is my Fellow buy and a new clutch Who Show signs of weakness)
2 recent pics :p
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/381649_136204899824544_100003051050144_155648_217336248_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc7/390021_136206693157698_100003051050144_155652_2130900292_n.jpg
Votre couleur de roue fonctionne bien avec la peinture de voiture.
Try this if you need to translate. It seems to work, if the above makes sense! :)
Click the blue arrow to reverse the languages.
http://www.microsofttranslator.com/?ref=TThis&from=en-US&to=fr-FR
You have Rota P-45R wheels? http://www.rotawheels.com/wheels.asp?wheelid=31
Edited by Morpheus (see edit history)
Hi there and welcome!
About your problem:
Make the original seq. setup work before you up the boost or use the TTC setup! And find someone who has worked on and tuned Supras!!
Shortlist:
-Remove the ETTC and go back to the original seq. setup
-Go back to stock boost
-Get an AFR
-Test the boost and AFR values
Good luck!
Dennis
My problem comes to the crossing of the turbo 2nd, (I have a switch for ettc/seq)
in sequential, 1.2 bar without any worries I took only on the first turbo as soon as the passage to the turbo 2nd I have a problem, now I turn a 1 bar with a peak a 1.2 bar and I have no more cuts
a problem of bcc was assumed (settled a 4 3v), tested, and not of differences
Candle problem (gap), tested and not differences
is this serious roll without restrictor on jdm?
I know that I must absolutely an afr to see how I turn
I have never seen anyone with this problem, some have turned a 1.4 bar without cuts, I exceeded 1 bar have concerns
That will be the translator, I think! :D
Presumably you meant sparkplug gap?
It looks to me like a basic timing problem caused maybe by a bad ground or over-rich condition, that is assuming that it's all degreed properly? Do you ever get flames from the exhaust? :)
Yes translation c'est error Although sparkplug gap;)
Yes I have return of flame, the switch or the downshift
during the dyno session , apparently my car felt very hard the essence, which under would hear roll too rich
There is no way to resolve it with the bcc (change the value to reduce the wealth)
Je pense qu'il serait mieux de parler votre meilleur anglais, comme le traducteur est rendant pire parfois :D
Je ne vous comprends pas parfois! :)
L'un des modérateurs est le français, ou devrait connaître la langue beaucoup mieux que moi, comme il a grandi là, si je me souviens bien. Il a appelé Lbm ici. Peut-être il peut vous aider avec la traduction? :)
Jonathan,
the fact that you smell the fuel is due to the absence of cats. If you have heavy exhaust flames and pops, it may be an indication of too much fuel being injected, thus the mixture being too rich.
Don't forget that 1.2 bar is the highest you should take out of the stock j-spec tubbies ... I was running 1.4 bar when I was BPU, but that was on euro-spec turbos.
I would replace the spark plugs and check the ignition pack. I had the same problem on my Supra on my single setup, and it ended up being a faulty HKS DLI ... so I guess it'll be an ignition problem.
To be on the safe side, install a AFR gauge .. better be safe than sorry.
Salutations
Luc
