Luxluc Posted September 29, 2014 Share Posted September 29, 2014 Lee. My plastic undertray came loose. Will your aluminum one fit with my TS front and actual screamer pipe routing (you know my car )?? Link to comment Share on other sites More sharing options...
Krister Posted September 29, 2014 Share Posted September 29, 2014 Any plans for an aluminium bumper undertray? Link to comment Share on other sites More sharing options...
Lee P Posted September 29, 2014 Share Posted September 29, 2014 Lee. My plastic undertray came loose. Will your aluminum one fit with my TS front and actual screamer pipe routing (you know my car )?? Yes Luc will fit fine :-) Any plans for an aluminium bumper undertray? We have looked at it. Will probably have to be 3 peice as doing it in one is tricky Link to comment Share on other sites More sharing options...
Luxluc Posted September 29, 2014 Share Posted September 29, 2014 Do you have these in stock Chief? Link to comment Share on other sites More sharing options...
DaveR Posted October 19, 2014 Share Posted October 19, 2014 Any plans for an aluminium bumper undertray? We have looked at it. Will probably have to be 3 peice as doing it in one is tricky I'm in for one of these if / when you get it made, 1-, 2-, 3- or 50-piece! Link to comment Share on other sites More sharing options...
MattP Posted April 11, 2015 Share Posted April 11, 2015 Fitted my SRD Undertray today very happy with it I would 100% recommend this product it smartens up the underneath and is much better at keeping crap out as opposed to the saggy old plastic OEM units.. Thanks Lee.. Link to comment Share on other sites More sharing options...
Lee P Posted April 11, 2015 Share Posted April 11, 2015 thats great, thank you for the feedback Link to comment Share on other sites More sharing options...
Phlukey Posted April 11, 2015 Share Posted April 11, 2015 (edited) Lee, would you be able to fit one of these to my car? Not sure whether the TRD kit and screamer pipes will make a difference or not? Would look really nice once the underside has been finished in white by Baldy Edited April 11, 2015 by Phlukey (see edit history) Link to comment Share on other sites More sharing options...
Big Mark Posted April 11, 2015 Share Posted April 11, 2015 (edited) Hoping to order one of these in the next month or two as I have the saggy factory undertray still. I know that I need to dril out and tap several of my old bolts that have previously been snapped off. Do these come with the bolts? Just seen that they do. Even better!!! Edited April 11, 2015 by Big Mark (see edit history) Link to comment Share on other sites More sharing options...
Lee P Posted April 11, 2015 Share Posted April 11, 2015 Lee, would you be able to fit one of these to my car? Not sure whether the TRD kit and screamer pipes will make a difference or not? Would look really nice once the underside has been finished in white by Baldy Yes no problem will fit fine Hoping to order one of these in the next month or two as I have the saggy factory undertray still. I know that I need to dril out and tap several of my old bolts that have previously been snapped off. Do these come with the bolts? Just seen that they do. Even better!!! Yep comes with new fixings, very comon for the original ones to snap off. Link to comment Share on other sites More sharing options...
Phlukey Posted April 11, 2015 Share Posted April 11, 2015 Cool, add one to the list then please mate Link to comment Share on other sites More sharing options...
MattP Posted April 11, 2015 Share Posted April 11, 2015 Yes no problem will fit fine Yep comes with new fixings, very comon for the original ones to snap off. I only had one snap it was a miracle, I drilled it out though so all good.. Link to comment Share on other sites More sharing options...
Jellybean Posted April 21, 2015 Share Posted April 21, 2015 Lee, would you be able to fit one of these to my car? Not sure whether the TRD kit and screamer pipes will make a difference or not? Would look really nice once the underside has been finished in white by Baldy Just on the TRD front Bumper, I mocked it up the weekend and looks like it may need to be modified to fit Will try take a look again this weekend, I may need to remove the bumper but it was catching; will be a PITA if you have the oil filter in the stock location, everytime you do an oil change you will need to remove the front bumper I may need to either cut or maybe try reshape the Aluminium Link to comment Share on other sites More sharing options...
Phlukey Posted April 22, 2015 Share Posted April 22, 2015 Thanks for the heads up Jellybean Lee will be fitting my under tray while the car is at SRD, so I'm sure he'll modify it accordingly where it needs it in order to fit. It'll be Lee doing all the oil changes on mine, so I'm sure he'll mod it to prevent him having to remove the front bumper every time I need an oil change Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 22, 2015 Share Posted April 22, 2015 I've never removed my undertray to perform an oil change....! You can get at the filter all you need from above, and below via the transmission tunnel. Link to comment Share on other sites More sharing options...
Jellybean Posted April 24, 2015 Share Posted April 24, 2015 TRD Bumper install So had a go at fitting the tray last night , it will not need to be modded but the front bumper will have to come off; where it bolts to up under the oil pump area , there are no threads on the holes to thread the nut through so I will need to use a nut to fasten it , even if the holes where threaded , it is too tight to get your hands in there. to even use a self taping screw or cable tie With the TRD bumper , if you have the oil filter in the OEM location off the side of the block, you will need to remove it come oil change time I did put some rice in there so hopefully during the nite some Asian person will come along and fix it for me Link to comment Share on other sites More sharing options...
Big Mark Posted April 25, 2015 Share Posted April 25, 2015 Got mine at home waiting to go on over the May Bank holiday. My old plastic undertray is looking very sorry for itself so time to put it out of it's misery. Link to comment Share on other sites More sharing options...
MattP Posted April 25, 2015 Share Posted April 25, 2015 Had the car on the lift the other day it's surprising how much neater the car looks with just this tray changed the plastic ones have had their day IMO Link to comment Share on other sites More sharing options...
Rob W Posted April 25, 2015 Share Posted April 25, 2015 alot neater and fits perfect. Well happy with mine, now just want the stock undertray that goes from the front bumper to the cross member to finish it of. Link to comment Share on other sites More sharing options...
MattP Posted April 25, 2015 Share Posted April 25, 2015 alot neater and fits perfect. Well happy with mine, now just want the stock undertray that goes from the front bumper to the cross member to finish it of. I was thinking that I remember lee saying he may make up a 3 piece unit.... Hurry up and mock one up for us Lee Link to comment Share on other sites More sharing options...
jazz1 Posted April 25, 2015 Share Posted April 25, 2015 I think I will have to have one . Link to comment Share on other sites More sharing options...
Lee P Posted February 10, 2017 Share Posted February 10, 2017 These are now available in a black powder coated finish which is £25 extra Link to comment Share on other sites More sharing options...
Luxluc Posted February 11, 2017 Share Posted February 11, 2017 Great addition mate. Can't wait to get mine mounted. Link to comment Share on other sites More sharing options...
bayside_supra Posted February 11, 2017 Share Posted February 11, 2017 The black is nice. I would have had this on mine if it was available at the time. I take it you can do the front bumper undertrays like this too? Link to comment Share on other sites More sharing options...
Lee P Posted February 11, 2017 Share Posted February 11, 2017 Yes we have those in stock, pics in the other thread The black is nice. I would have had this on mine if it was available at the time. I take it you can do the front bumper undertrays like this too? /QUOTE] Link to comment Share on other sites More sharing options...
