Lee P Posted July 23, 2012 Share Posted July 23, 2012 Will have to have a look through the build threads I haven't got any pics to hand at the moment. It puts the battery in the wheel well to the left hand side, cable comes up through the grommet in the boot floor. Quote Link to comment Share on other sites More sharing options...
Hoppy Posted August 9, 2012 Share Posted August 9, 2012 This is how i mounted mine: http://img689.imageshack.us/img689/3812/p1010972n.jpg http://img21.imageshack.us/img21/4063/p1010974bh.jpg I bought 2 x 12mm rubber nuts, cut the nut off the end, slid the rubber sleeves over the cables, drilled 2 holes in the boot floor and snugly pushed the sleeves into the drilled holes (thus protecting the cables from any sharp edges, and keeping any moister out.). I then feed the 12V power cable through some armor cable sleeve and sent it to the front. Note: To fit the battery in this position you will need to temporarily drop the fuel tank a little to allow you get the bolts in from underneath, then tighten the tank straps back. I used button head bolts, so they would not cut into the fuel tank. There's easier ways of doing it i know, but this was the only space i had to mount the battery, due to my ice install. Hope this helps Quote Link to comment Share on other sites More sharing options...
Lee P Posted August 9, 2012 Share Posted August 9, 2012 Thanks Hoppy, appriciate at that. We are fitting one at the moment ourselves so will post more pics once done. Quote Link to comment Share on other sites More sharing options...
Hoppy Posted August 9, 2012 Share Posted August 9, 2012 Will have to have a look through the build threads I haven't got any pics to hand at the moment. It puts the battery in the wheel well to the left hand side, cable comes up through the grommet in the boot floor. thanks also for putting the re-location kit together for sale. As originally I didn't have a clue what components I needed. It simplified things, Big time keep up the good work guys Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted January 30, 2014 Share Posted January 30, 2014 Anyone have any more pictures of these installed? Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted February 7, 2014 Share Posted February 7, 2014 guess not Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 11, 2014 Share Posted February 11, 2014 guess not I should be able to find a pic What is it you need to know? Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted February 11, 2014 Share Posted February 11, 2014 Just want to see different variations of how people are implementing it. My current optima configuration is getting in the way of my coolant reservoir relocation. Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 11, 2014 Share Posted February 11, 2014 We usually mount them in the wheel well on the rear left side. If you use an 075 battery it won't protrude too much into the boot as well Quote Link to comment Share on other sites More sharing options...
