Inlet manifold help
jimojameso
Hello all,
Just putting my inlet manifold back on yesterday and have a couple of questions i need some help with. I have attached some photo's of the parts in question.
Firstly on the back left of the manifold there is a bit that bolts on. Which order does the diaphram and rubber bit go inside. I know the gasket goes on the outside but i can't remember which way round the other two bits go. A diagram would be great if anyone has one!
Secondly. I have one last vacuum pipe which i haven't accounted for. Its pictured and comes out the bit where those two rubber pipes go under the manifold and attach to the bit that bolts on the back left.
Thanks
James :)
did you manage to find where the vacuum went?
ive just been removing mine tonight, i beleive it goes here
to the "idle air reference hose for evap system"
when i say ive been removing mine tonight, i have undone every single bolt and vacuum, and on the very last one i rounded off!!!! :(
obsolutly gutted and spent an hour on the one bolt. its the one thats on the long manifold support, which goes from the manifold to the bottom of the block.
