Kevlar Timing/aux belts
Pero
I do need kevlar belts yes. It's actually just the aux belt I need, and it's not for a Supra. :taped:
It's for a Fiat Coupe. We went to get it remapped on Thursday. It made 570bhp and 450lbft on the dyno, but when the mapper took it on the road to fine tune, the aux belt shredded, took out the cam belt and destroyed the engine. This is a common occurrence and a very expensive one, so I need something that will hold up under the torque.
There are plenty of none automotive suppliers of ribbed belts in Kevlar reinforced material, just search on Google for them, and hope they do a size that is near enough, length wise.
There aren't plenty actually. I'm looking for a 6 rib v-belt, and I cannot find a single supplier anywhere.
I think the belt goes when you're giving it beans and then lift off without dipping the clutch.
The sudden force of the engine breaking looks like it's too much for the belt. This is the single most common problem on high powered Coupes.
There are guard pullies available to help keep the aux belt away from the cam belt when it goes, but sometimes it still makes its way through. Then it's engine rebuild time.
Yes, it's a harmonics problem, very common when cars are modded, especially with a fierce clutch. A "wave" forms in the belt then an oscillation, it flows around to a pulley and either comes off or starts to fray. Automatic adjusters don't help, either, as they have give in them. I had the exact same problem with the PAS belt on my RB26 engine when I fitted a triple plate clutch and a sequential dog box. I had to make an idler pulley to run on the back of the longest belt run. I have photos.
A stock belt SHOULD be fine, but how is it tensioned, with a spring loaded automatic adjuster or a manually adjusted, fixed one? A manual type is better for engines that see shock loads on gear changes, or that are inertia free enough to be ultra responsive (highly unlikely for a supercharged road car engine). I prefer manually adjusted tensioners for race applications.
The idler pulley needs to just press very lightly against the back of the belt, maybe bowing it in one eighth of an inch maximum. It's to stabilise it, not re route or deflect it. If you post a photo or link showing clearly the stock belt and tensioner set up I can advise, it's a fairly common issue, and why Toyota fit a damper on the adjuster arm on manual TT models. (It's really `cos they know the Yanks can't change gear in a manual without sending shock waves through the drive train, but they are too Japanese and polite to actually say this out loud... ;))
The way the belt is routed, there is not 1 long run of the belt like on the Supe, but two shorter equally spaced runs between two pulleys.
I'll see if I can get some pics up. I think another problem is possibly the tensioner pulley is made from plastic and doesn't have a lip, so under extreme conditions it gives ever so slightly and causes the belt to jump off.
I'll need to find a solution as my tuner's car had the engine go because of this on Thursday, and I'm running an even bigger turbo than him. Can't have the same happen to me or I'll kill the mapper. Lol
