Kev.O Posted May 5, 2013 Share Posted May 5, 2013 I have a similar issue where the security LED is continuously illuminated and the switch will lock the door, though the remote central locking won't work. I have followed the guide and found this ECU: Is this different because it has an aftermarket Toyota fitted alarm system? Quote Link to comment Share on other sites More sharing options...
Kev.O Posted May 6, 2013 Share Posted May 6, 2013 Just an update for everyone my Central locking/Fob and security light problem following the advice this I found on here... SUBJECT: TOYOTA 5000 THEFT DETERRENT SYSTEM STARTING VEHICLES WITH A FLAT BATTERY Guidance If you wish to jump start a vehicle ( or reconnect a fully charged battery ) to a vehicle which is fitted with a Toyota 5000 Theft deterrent system, the following procedure should be followed. This should prevent the remote control handsets locking out . Before disconnecting the battery 1) Turn off the siren with the master key. The siren has its own Ni-Cad Battery which will cause it to sound when the vehicle battery is disconnected Unless it is switched off. 2) Remove the DOME Fuse. This is located under the bonnet in the main junction box. 3) Disconnect and Remove the battery. When Re-connecting the battery . 1) Ensure the siren is turned off with the master key . 2) Ensure DOME Fuse is removed . 3) Refit the battery and reconnect the terminals correctly. 4) Turn on the ignition . 5) Insert the DOME Fuse. 6) Turn off the ignition The Hazard lights should now be flashing 7) Cancel the alarm using the remote control handset . Ther indicator lights should stop flashing . It may be necessary to hold the Black left hand button down for up to 15 seconds (15 seconds means 15 seconds or longer ) – until the car Locks or Unlocks itself 8) You should now be able to start the engine. N.B. Remember to turn on the siren with the master key. (Note : if the system should not respond to the remote controls check for re-synchronisation . If this is not successful, the following procedure must be followed: With the positive terminal of the battery connected and the negative terminal disconnected . 1) Turn Ignition on 2) Reconnect the negative terminal of the battery 3) Turn the ignition off 4) Press the left hand black button of the remote controll for 15 seconds To re synchronise. The other remote if availible may also require re synchronisation. Happy days Although my traction control button and spoiler down button don't want to work very often?? Also the Auto box Letters at the bottom of the lever don't like to light up very often either?? Dodgy connection I'm guessing?? Anyone else had these problems? Massive thank you for the post. My remote central locking is now working again Quote Link to comment Share on other sites More sharing options...
Guest Camron Posted May 29, 2013 Share Posted May 29, 2013 (edited) I think mostly the people are facing the same security alarm problem and also the light blinking problem i think these all are security alarm error and you contact the manufacturer or read the manual because all the information are given there. brisbane security officers Edited June 6, 2013 by Camron (see edit history) Quote Link to comment Share on other sites More sharing options...
tina n paul Posted November 22, 2015 Share Posted November 22, 2015 just to add its not always the red box , in my case the door motor actuator is dead. I just did a test on the loom that plugs into it .good signal on open and close but door lock not working , Quote Link to comment Share on other sites More sharing options...
