just noticed my rear brakes can anyone help
ashbuster
hey guys
when i was looking at the car today i noticed my rear pads are gone
i need some new ones but i need to make sure my jspec has uk rear calipers
i have been told i have jspec on the front and uk on the rear
heres a couple of photos
front jap???
rear uk???
reason im asking is because the guy in karpartz wants me to show him a photo of the pads
instead of me taking the pad out is there any photos about of a uk spec rear pad?
carnt be doing that untill after new year mate, just want some normal pads for now, maybe this has soemthing to do with my problem as they were on metal
You might well be needing new discs as well then.
Also, I'd not fancy driving with Jap fronts and UK rears, the braking balance will be all out.
Fit Toyota pads and discs :)
I can get those for you at a good price just let me know, you have my mobile number :)
Check the calipers are ok first, it could be down to failing outer
seals causing the pistons to start to seize !!
Infact if their 17 yr old calipers and havent been refurbed i'll bet a round of
drinks they will need doing :)
Pop the pads out and have a good look and ease the pistons back into the caliper, if
their really hard to push back then i'd suggest an overhaul is due
yeah mate will have to upgrade the front too
am i right in saying the part number is the one ive highlighted in red for the rear pads,
BRAKES:
frt pads-#04465-14150 [TT for 4pot calipers]
frt shims-#04945-14110[TT]
frt clips-#04947-14010 [TT]
frt pad pins-#90240-06019[TT]
rear pads-#04466-14040 [TT]
rear shims-#04946-14030 [TT]
rear clips-#04948-14010 [TT]
rear pad pins-#90240-06017 [TT]
frt rotor rh-#43512-14200 [TT]
frt rotor lh-#43516-14030 [TT]
rear rotors-#42431-14150 [TT]
cal kit frt-#04479-14140 [TT]
cal kit rear-#04479-14130 [TT]
cal assy frt rh-#47730-14260 [TT]
cal assy frt lh-#47750-14270 [TT]
cal assy rear rh-#47730-14270 [TT]
cal assy rear lh-#47750-14280 [TT]
frt pads-#04465-14081 [NA and 2pot caliper TT]
frt shims-#04945-14010 [NA]
frt clips-#04947-24030 [NA]
frt cal pins-#47715-24010 [NA]
rear pads-#04466-30030 [NA]
rear shims-#04946-24010 [NA]
rear clips-#04948-50010 [NA]
rear cal pins main-#47715-06030 [NA]
rear cal pins sub-#47715-06020 [NA]
frt rotors-#43512-14190 [NA]
rear rotors-#42431-30140 [NA 93.5-95]
rear rotors-#42431-30240 [NA 96-98]
cal kit frt-#04479-14120 [NA]
cal kit rear-#04479-24030 [NA]
cal assy frt rh-#47730-24082 [NA 93.5-94]
cal assy frt lh-#47750-24082 [NA 93.5-94]
cal assy frt rh-#47730-14281-84 [NA 95-98]
cal assy frt lh-#47750-14291-84 [NA 95-98]
cal assy rear rh-#47730-14240-84 [NA]
cal assy rear lh-#47750-14240-84 [NA]
or does anyone have a photo of a pad thats the right one
I would seriously consider buying a set of 2nd hand jspec rears until you can get a set of UK spec fronts. The brake balance will be miles out bud and the one thing you REALLY don't want to have is the back locking up before the front. Having small fronts and large rears is just plain dangerous.
This. Balance them up with either JSpec rears or a set of UK fronts.
ESPECIALLY in this weather, where tyres will lock easier.
hey guys
had to rush out and pay for the pads so didnt read the messages
cost £35 for pads on the rear and looks like ill have to get front uk calipers then too
wont be untill after new year and im not driving the car now anyway so will be fine untill after that
i take it the front discs will be different too then? so if upgrading the front to uk spec i would need new uk discs?
hey guys
Yeah, you'll also need to cut off your dust shields if they haven't been removed already (Thinking that maybe the previous owner took the front UKs off to sell or something?).
