ashbuster Posted December 16, 2011 Share Posted December 16, 2011 hey guys when i was looking at the car today i noticed my rear pads are gone i need some new ones but i need to make sure my jspec has uk rear calipers i have been told i have jspec on the front and uk on the rear heres a couple of photos front jap??? rear uk??? reason im asking is because the guy in karpartz wants me to show him a photo of the pads instead of me taking the pad out is there any photos about of a uk spec rear pad? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 16, 2011 Share Posted December 16, 2011 Odd set up but yes UK rears, J spec fronts Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 i bought it like it mate the whole car seems a messed up setup should have checked it over properly but i trusted someone i shouldnt have anyway any ideas on what pads i need when ordering from karpartz Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 16, 2011 Share Posted December 16, 2011 Dude, get your car transported to Chris Wilson. He'll give it a go over and supply you with pads. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 carnt be doing that untill after new year mate, just want some normal pads for now, maybe this has soemthing to do with my problem as they were on metal Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 16, 2011 Share Posted December 16, 2011 carnt be doing that untill after new year mate, just want some normal pads for now, maybe this has soemthing to do with my problem as they were on metal You might well be needing new discs as well then. Also, I'd not fancy driving with Jap fronts and UK rears, the braking balance will be all out. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 16, 2011 Share Posted December 16, 2011 (edited) Fit Toyota pads and discs I can get those for you at a good price just let me know, you have my mobile number Check the calipers are ok first, it could be down to failing outer seals causing the pistons to start to seize !! Infact if their 17 yr old calipers and havent been refurbed i'll bet a round of drinks they will need doing Pop the pads out and have a good look and ease the pistons back into the caliper, if their really hard to push back then i'd suggest an overhaul is due Edited December 16, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 yeah mate will have to upgrade the front too am i right in saying the part number is the one ive highlighted in red for the rear pads, BRAKES: frt pads-#04465-14150 [TT for 4pot calipers] frt shims-#04945-14110[TT] frt clips-#04947-14010 [TT] frt pad pins-#90240-06019[TT] rear pads-#04466-14040 [TT] rear shims-#04946-14030 [TT] rear clips-#04948-14010 [TT] rear pad pins-#90240-06017 [TT] frt rotor rh-#43512-14200 [TT] frt rotor lh-#43516-14030 [TT] rear rotors-#42431-14150 [TT] cal kit frt-#04479-14140 [TT] cal kit rear-#04479-14130 [TT] cal assy frt rh-#47730-14260 [TT] cal assy frt lh-#47750-14270 [TT] cal assy rear rh-#47730-14270 [TT] cal assy rear lh-#47750-14280 [TT] frt pads-#04465-14081 [NA and 2pot caliper TT] frt shims-#04945-14010 [NA] frt clips-#04947-24030 [NA] frt cal pins-#47715-24010 [NA] rear pads-#04466-30030 [NA] rear shims-#04946-24010 [NA] rear clips-#04948-50010 [NA] rear cal pins main-#47715-06030 [NA] rear cal pins sub-#47715-06020 [NA] frt rotors-#43512-14190 [NA] rear rotors-#42431-30140 [NA 93.5-95] rear rotors-#42431-30240 [NA 96-98] cal kit frt-#04479-14120 [NA] cal kit rear-#04479-24030 [NA] cal assy frt rh-#47730-24082 [NA 93.5-94] cal assy frt lh-#47750-24082 [NA 93.5-94] cal assy frt rh-#47730-14281-84 [NA 95-98] cal assy frt lh-#47750-14291-84 [NA 95-98] cal assy rear rh-#47730-14240-84 [NA] cal assy rear lh-#47750-14240-84 [NA] or does anyone have a photo of a pad thats the right one Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 are these uk spec ones Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 16, 2011 Share Posted December 16, 2011 Why dont you just get Toyota pads and discs from Toyota B'ham near Fort Dunlop. Pads are £42.72 Discs are £115.31 all inc vat to me Quote Link to comment Share on other sites More sharing options...
BOB B Posted December 16, 2011 Share Posted December 16, 2011 If you look in the "for sale" section on here, "b'have" is selling some part used UK spec pads and discs and a separate set of new pads. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 16, 2011 Share Posted December 16, 2011 I would seriously consider buying a set of 2nd hand jspec rears until you can get a set of UK spec fronts. The brake balance will be miles out bud and the one thing you REALLY don't want to have is the back locking up before the front. Having small fronts and large rears is just plain dangerous. Quote Link to comment Share on other sites More sharing options...
johnny g Posted December 16, 2011 Share Posted December 16, 2011 I would seriously consider buying a set of 2nd hand jspec rears until you can get a set of UK spec fronts. The brake balance will be miles out bud and the one thing you REALLY don't want to have is the back locking up before the front. Having small fronts and large rears is just plain dangerous. This. Balance them up with either JSpec rears or a set of UK fronts. ESPECIALLY in this weather, where tyres will lock easier. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 hey guys had to rush out and pay for the pads so didnt read the messages cost £35 for pads on the rear and looks like ill have to get front uk calipers then too wont be untill after new year and im not driving the car now anyway so will be fine untill after that i take it the front discs will be different too then? so if upgrading the front to uk spec i would need new uk discs? Quote Link to comment Share on other sites More sharing options...
Scott Posted December 16, 2011 Share Posted December 16, 2011 hey guys had to rush out and pay for the pads so didnt read the messages cost £35 for pads on the rear and looks like ill have to get front uk calipers then too wont be untill after new year and im not driving the car now anyway so will be fine untill after that i take it the front discs will be different too then? so if upgrading the front to uk spec i would need new uk discs? Yeah, you'll also need to cut off your dust shields if they haven't been removed already (Thinking that maybe the previous owner took the front UKs off to sell or something?). Quote Link to comment Share on other sites More sharing options...
ashbuster Posted December 16, 2011 Author Share Posted December 16, 2011 (edited) yes and shouldnt have done but didnt notice when i bought the car as it was dark so ill need to buy them now needs alot of work but will get it all sorted Edited December 16, 2011 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
