andz222 Posted December 14, 2011 Share Posted December 14, 2011 hi people there are two holes on the solenoid that are left open ie no breather hoses connected to it just the sensor shall i block them off Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 14, 2011 Share Posted December 14, 2011 need more information then that mate what are you doing would help Quote Link to comment Share on other sites More sharing options...
andz222 Posted December 14, 2011 Author Share Posted December 14, 2011 i opened my bonnet had a look behind the engine and there was nothing connected to the solenoid only the sensor part of it Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 14, 2011 Share Posted December 14, 2011 you are probably running in ttc, this is a mod done to make both turbos spool at the same time and not use the sequencial system its normall used for checking a vac leak or if some other problem with the sequencial set, the fuel map will be way off with that set up, some people like it some dont or you might have a boost controller fitted some where search true twin or boost controller Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 14, 2011 Share Posted December 14, 2011 look here http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Quote Link to comment Share on other sites More sharing options...
andz222 Posted December 14, 2011 Author Share Posted December 14, 2011 i think i will just cap them off Quote Link to comment Share on other sites More sharing options...
hodge Posted December 14, 2011 Share Posted December 14, 2011 Do you have a boost controller Quote Link to comment Share on other sites More sharing options...
andz222 Posted December 14, 2011 Author Share Posted December 14, 2011 yes greddy one Quote Link to comment Share on other sites More sharing options...
hodge Posted December 14, 2011 Share Posted December 14, 2011 That's why there not used. Just block um off mate. Quote Link to comment Share on other sites More sharing options...
andz222 Posted December 14, 2011 Author Share Posted December 14, 2011 yea will do Quote Link to comment Share on other sites More sharing options...
