JamieP Posted December 13, 2011 Share Posted December 13, 2011 Im doing a few jobs on my car over winter and want to add some braces to my IC pipes like in the picture attached, the braces are no problem but i want some of the threaded bar to weld on my pipes like i have circled in the picture, anyone know where i can get some? cant find anything. Cheers. Hope DARETT dont mind me using a picture of his bay. Link to comment Share on other sites More sharing options...
Morpheus Posted December 13, 2011 Share Posted December 13, 2011 http://www.gwr-fasteners.co.uk/aluminium-threaded-bar-290-c.asp Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2011 Author Share Posted December 13, 2011 http://www.gwr-fasteners.co.uk/aluminium-threaded-bar-290-c.asp I wont be screwing any nuts in that, wrong stuff dude. Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2011 Author Share Posted December 13, 2011 i have random bits of bar lying around. i would be able to make something up if you don't come up with anything. let me know if you can't find any. im assuming its just drilled and tapped. something like 316 stainless steal? EDIT: you want alloy, if u change ur mind i have stainless bar Got to be alley to weld to the IC pipes. If you carry on with the text speak you will get banned Noz, mods wont keep telling you. Link to comment Share on other sites More sharing options...
suprasurrey Posted December 13, 2011 Share Posted December 13, 2011 I have plenty of ally bar kicking around in my workshop, just let me know dimensions and i`ll knock some up for you. Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 13, 2011 Share Posted December 13, 2011 And it was all written normally? No. It wasn't. It still isn't. Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2011 Author Share Posted December 13, 2011 I have plenty of ally bar kicking around in my workshop, just let me know dimensions and i`ll knock some up for you. Good man, will have a measure up tomorrow and let you know, cheers. Link to comment Share on other sites More sharing options...
Morpheus Posted December 13, 2011 Share Posted December 13, 2011 http://aluminum-spacers.com/?gclid=COm94rD2_6wCFegmtAodo2Itmg If all else fails. Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2011 Author Share Posted December 13, 2011 http://aluminum-spacers.com/?gclid=COm94rD2_6wCFegmtAodo2Itmg If all else fails. Yank stuff will be imperial thread, no good to me, thanks for trying though, looks like im sorted now. Link to comment Share on other sites More sharing options...
supra matt Posted December 13, 2011 Share Posted December 13, 2011 here you go mate just incase you get stuck http://www.aluminiumwarehouse.co.uk/Aluminium-Round_Tube/c120_131/index.html Link to comment Share on other sites More sharing options...
J_Supra_07 Posted December 13, 2011 Share Posted December 13, 2011 If suprasurry dose not have the size your after drop me a pm as I have plenty also. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 13, 2011 Share Posted December 13, 2011 You might be better welding some drilled on a pair female tapped pieces of round ally bar onto the 2 I/C pipes and using anodised button heads to hold the anti spreader plate onto them. Link to comment Share on other sites More sharing options...
JamieP Posted December 13, 2011 Author Share Posted December 13, 2011 That's the plan but why anodised Chris? Link to comment Share on other sites More sharing options...
Lee P Posted December 13, 2011 Share Posted December 13, 2011 Let me know if you get stuck mate, my fabricator can knock some up for you. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 13, 2011 Share Posted December 13, 2011 That's the plan but why anodised Chris? They won't corrode in, and look and stay shiny Link to comment Share on other sites More sharing options...
David P Posted December 14, 2011 Share Posted December 14, 2011 Simplest way would be to use alloy rivnuts. http://www.rivetwise.co.uk/rivets/rivet-nuts.asp?product=flat-head-closed-end-rivet-nuts-aluminium-29 Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 14, 2011 Share Posted December 14, 2011 Actually, that set up is not good at all, thinking about itas the flex of the rubber coupling to disengage engine movement from the I/C pipework is removed, and you are trying to make that alloy bar feed engine movement into the rest of the pipework. You could use a bar with small rod ends on it, but it's complicated and messy. You could use tension springs instead of a bar. You really need a clamshell coupling here, that is pretty, and allows movement through O rings on ferrules. The best are Adel Wiggins ones. You could get rid of the rubber hose altogether then, and still have movement. http://www.hrpworld.com/index.cfm?form_prod_id=3918&action=product Link to comment Share on other sites More sharing options...
JamieP Posted December 14, 2011 Author Share Posted December 14, 2011 My engine is solid mounted Chris. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 14, 2011 Share Posted December 14, 2011 OK, that's that issue sorted then, sorry, didn't realise that Jamie Link to comment Share on other sites More sharing options...
