neil Posted December 11, 2011 Share Posted December 11, 2011 (edited) hi are the gearbox splines the same on the 5 speed mk4 and 6 speed mk4 gearbox thanks neil Edited December 11, 2011 by Gaz6002 (see edit history) Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 11, 2011 Share Posted December 11, 2011 Im not 100% sure on this but I think they would be diffrent as the gear sets are not the same. Sure someone will be around soon with definet answer. Quote Link to comment Share on other sites More sharing options...
little num Posted December 11, 2011 Share Posted December 11, 2011 why you need to know this anyway, the 5 speed clutch is a push type and the 6 speed clutch is pull type so you cant fit a v160 in place of a w58 and you cant do it w58 in place of v160. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 11, 2011 Share Posted December 11, 2011 Title edited to something more descriptive. It helps other members if you make an effort on your title making it easy to search Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 11, 2011 Share Posted December 11, 2011 If youre referring to output shafts for clutches then no. Quote Link to comment Share on other sites More sharing options...
David P Posted December 12, 2011 Share Posted December 12, 2011 (edited) W58 has a splined output, the Getrag V160/1 has a flange. Edited December 12, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 12, 2011 Share Posted December 12, 2011 hi are the gearbox splines the same on the 5 speed mk4 and 6 speed mk4 gearbox thanks neil Input shaft splines are different, the Getrag has a very coarse spline, the 5 speed a finer spline. Quote Link to comment Share on other sites More sharing options...
