W58 help needed please from auto to manual
Guest hoochie
Guest hoochie
Hi. after a little help. i have just ordered the clutch kit for when the conversion happens i have the mW58 flywheel also will this require longer bolts so the auto bolts will be to small? Or should i get all new pressure plate bolts and replace all with new. flywheel and plate bolts?? cheers in advance
