Noz Posted December 10, 2011 Share Posted December 10, 2011 is 2000 grade the finest you can get? Would this be fine enough to give a really nice clear finish for plastic, e.g. headlights? Link to comment Share on other sites More sharing options...
leet45single Posted December 10, 2011 Share Posted December 10, 2011 id go over that with megs plastx to give the final clean look Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 10, 2011 Share Posted December 10, 2011 I've got 2500 in the garage, not sure how much finer than that you can get though. Get it off ebay if you need some, loads cheaper on there than the likes of Halfrauds. Use 2k grit then megs plastix or G3 compound etc, it'll come up lovely then Link to comment Share on other sites More sharing options...
leet45single Posted December 10, 2011 Share Posted December 10, 2011 http://www.cleanyourcar.co.uk/engine-and-exterior/meguiars-plastrx/prod_283.html Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 10, 2011 Share Posted December 10, 2011 I use G3 and it comes up lovely Link to comment Share on other sites More sharing options...
Noz Posted December 10, 2011 Author Share Posted December 10, 2011 use those products after 2000/2500 grade then. job done!! will be working on this next weekend so need to start considering options. thanks guys Link to comment Share on other sites More sharing options...
jim Posted December 10, 2011 Share Posted December 10, 2011 I use 2000 grit on mine when cleaning them Noz, plenty of water and sand them by hand until they go White, then machine polish with g3. They come up like new Link to comment Share on other sites More sharing options...
merckx Posted December 10, 2011 Share Posted December 10, 2011 I know you can get 3000 grit. Have a go with some polish if you haven't already before you use sandpaper. You can get plastic polish and normal car polish of varying grades also work (T-cut and Farecla G3 etc). Link to comment Share on other sites More sharing options...
Littler Posted December 10, 2011 Share Posted December 10, 2011 I refurbed a few sets of lights, I've used 2000 then 3000 and 4000 to finish, followed by a good compound. Really makes them look new! Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 10, 2011 Share Posted December 10, 2011 2000 grit then a good polish is perfectly sufficient tbh. I'm going to do mine over the winter and thats what i will do and it will come up crystal clear. Link to comment Share on other sites More sharing options...
Noz Posted December 10, 2011 Author Share Posted December 10, 2011 ok cool, thanks for input guys. if the clear lense procedure isn't too hard to might give it ago with my main headlights. Link to comment Share on other sites More sharing options...
