chris blackwell Posted December 10, 2011 Share Posted December 10, 2011 Hi, Doing a full restoration on the car now but when it was on the road i noticed the front passenger side bolt kept coming loose causing the roof to rattle, obviously i could put some lock tight on it and it will solve this problem but I'd quite like to be able to remove it Has anyone else had a similar problem? I really dislike the system of removing the roof as it seems to take ages. I'd like to replace all the bolts and give the roof an overhaul if it's possible. Can you get replacement parts? I don't really want to get another roof as i've heard they are very expensive. The quick release thing on the fast and the furious film would be cool Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 10, 2011 Share Posted December 10, 2011 Let me know the response to this as I'd quite like to overhaul my roof. My drivers side seal leaks only slightly... Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 10, 2011 Share Posted December 10, 2011 On the instruction diagram found in the wallet for the bolts and clips. it show a particular sequence for tightening the bolts. Mine seems to be fine after I've followed the sequence. but when i randomly tighten from corner to corner i seem to get the rattling quite a lot. Quote Link to comment Share on other sites More sharing options...
Sakey Posted December 10, 2011 Share Posted December 10, 2011 (edited) Make sure when you put the roof on it its on a flat road and also they do come loose after first tightening it. Re-tightening them after a drive usually solves the problem on mine. As for replacing bolts they can be replaced not sure how much they are from Toybota. Pricey I guess Edited December 10, 2011 by Sakey (see edit history) Quote Link to comment Share on other sites More sharing options...
chris blackwell Posted December 10, 2011 Author Share Posted December 10, 2011 Thanks for this guys, I haven't been tightening them in any sequence, just randomly and I haven't done it on a flat surface. Will try this when it's back on the road. Do you know what the sequence for tightening them is? I don't seem to have an instruction diagram. Quote Link to comment Share on other sites More sharing options...
dude Posted December 10, 2011 Share Posted December 10, 2011 You need to dismantle the roof and tighten all the captive bolts, its not too bad a job but they are whats rattling not the hold down bolts, The F&F bit is just the parking lock on the aero top, you have that already but it will not hold the roof down at any sort of speed. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 10, 2011 Share Posted December 10, 2011 OMG! Thats so cool. Never knew my aerotop has a 'parking lock'. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 10, 2011 Share Posted December 10, 2011 What's the sequence of tightening? And what else is it we tighten other than the wobble bolts? Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 10, 2011 Share Posted December 10, 2011 My Supra is wrapped away for the winter, so have no way of seeing the diagram. Maybe someone else has the wallet and diagram. From memory is was passenger front, passenger rear, driver rear, driver front, centre lock. Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 10, 2011 Share Posted December 10, 2011 the pic in an owners manual i'm looking at goes 1)drivers rear 2)passenger rear 3)passenger front 4)drivers front 5)the centre one Quote Link to comment Share on other sites More sharing options...
chris blackwell Posted December 10, 2011 Author Share Posted December 10, 2011 Nice one mate, thats perfect Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 10, 2011 Share Posted December 10, 2011 This is the only sure means of fixing the damned things: http://www.ebay.co.uk/itm/Murex-Transmig-253-320-amp-mig-welder-removable-wire-feed-unit-3phase-gwo-/120822068116?pt=LH_DefaultDomain_3&hash=item1c218e7394 Quote Link to comment Share on other sites More sharing options...
dude Posted December 10, 2011 Share Posted December 10, 2011 Its the fixings inside the roof that are rattleing. The TIG will take care of it !!! Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 10, 2011 Share Posted December 10, 2011 I was nearly right. 3 out 5 LOL the pic in an owners manual i'm looking at goes 1)drivers rear 2)passenger rear 3)passenger front 4)drivers front 5)the centre one Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 10, 2011 Share Posted December 10, 2011 there is normally a pic under the centre console storage box (I'm not 100% convinced its the same as what I posted above but it's too cold for me to be arsed to pop out and check) Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 10, 2011 Share Posted December 10, 2011 This also help with leaking? Quote Link to comment Share on other sites More sharing options...
dude Posted December 11, 2011 Share Posted December 11, 2011 This also help with leaking? Not really, if it leaks its normally because the water drains are blocked. Quote Link to comment Share on other sites More sharing options...
The Raven Posted December 11, 2011 Share Posted December 11, 2011 The rubber is crap. These cars are old. The aero was never ment to see our weather and salt ect. Check the drains, think about replacing the rubbers. Quote Link to comment Share on other sites More sharing options...
dude Posted December 11, 2011 Share Posted December 11, 2011 Mine leaked in the corners so I used a dollop of rubber friendly grease and it never leaked again. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 11, 2011 Share Posted December 11, 2011 Rubber friendly grease? Such as? And how do I clear the water drains? Cheers fellas! Quote Link to comment Share on other sites More sharing options...
dude Posted December 11, 2011 Share Posted December 11, 2011 Rubber friendly grease? Such as? And how do I clear the water drains? Cheers fellas! http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=190553036719&clk_rvr_id=294889763468 Quote Link to comment Share on other sites More sharing options...
straightsix Posted December 12, 2011 Share Posted December 12, 2011 OMG! Thats so cool. Never knew my aerotop has a 'parking lock'. Or a boot release inside the car...... Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 12, 2011 Share Posted December 12, 2011 (edited) Vaseline on all the rubber seals has solved my slight leak. Edited December 14, 2011 by Josh42 (see edit history) Quote Link to comment Share on other sites More sharing options...
