Help!!! O/D light flashing
bullet_uk
Hi all I should start by saying I use my na daily and this has never happerend before. Filled up with fuel on my way to work this morning then got 2 minutes down the road and my over drive light starts flashing, I turned off the engine then it stopped, got two minutes down the road and started again so I flicked the O/D button and made the light solid left it on for a while then turned it off and it didn't flash again. Should I be worried?
Check for error codes using the paperclip trick. Sounds like a flaky odometer or speed converter to me (search for "code 42"). If your MIL light (orange engine icon) isn't working, it would be worth getting that fixed (probably a blown bulb or more likely, a dry solder on the circuit board it sits on).
