TUNERAIDER Posted December 6, 2011 Share Posted December 6, 2011 Hello all, As the title says, had a flat, (2inch screw through the rear off side Tyre). Only a £10 repair so not too bad. when putting the wheel back on i had no purchase on the wheel nut, just spinning. managed to get 3 on and went to the garage the next day, (today). Got the usual sharp intake of breath followed by the long exhale, with a slight shake of the head that any mechanic worth his salt learns early on. But for a change the problem was obvious. someone had put the wheel nuts back on using the pneumatic wrench and not tightened them by hand first. Two of the bolts had no thread for the first inch and the thread-less part was a lot thinner than the rest of the bolt. its lucky the wheel didnt come off before, with the potholes and mountains disguised as speed bumps around my area. Ended up ordering 5 new bolts for Thursday, looking at £130 fitted as im using Toyota for this. got plans for Friday, and i don't know if the garage that fitted the discs, breaks and all did the damage. Truth be told it may have been like it for ages and there are a lot of suspects. New whels, calipers and other bits that involve the removal of the wheel. So i guess the moral is. Check your nuts after visiting the garage. not all mechanics are gentle with them. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 6, 2011 Share Posted December 6, 2011 I'd be checking the other wheel nuts and the caliper bolts etc as well Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 So i guess the moral is. Check your nuts after visiting the garage. not all mechanics are gentle with them. Most mechanics I meet in these places are knuckle dragging spanner monkeys who wouldn't know finess if she sat on their face. If it doesn't go on or come off with a hammer or a impact gun they are stumped. Always, always, always after leaving any garage for any sort of work where the wheels come off, loosen off your wheel nuts and re-tighten them yourself by hand (using a wrench of course). I cringe everytime I get a tyre fitted and watch them pick up the impact gun. Twice now I've tapped the guy about to put my wheel on using one and asked him if I could do it myself to save the studs from shearing at speed. Both times I've received a very confused look from them. Quote Link to comment Share on other sites More sharing options...
TUNERAIDER Posted December 6, 2011 Author Share Posted December 6, 2011 did have a quick look nothing noticeable, shes going in on January for the once-over all over. Will point this out to them when shes up though thanks. Quote Link to comment Share on other sites More sharing options...
TUNERAIDER Posted December 6, 2011 Author Share Posted December 6, 2011 Most mechanics I meet in these places are knuckle dragging spanner monkeys who wouldn't know finess if she sat on their face. If it doesn't go on or come off with a hammer or a impact gun they are stumped. Always, always, always after leaving any garage for any sort of work where the wheels come off, loosen off your wheel nuts and re-tighten them yourself by hand (using a wrench of course). I cringe everytime I get a tyre fitted and watch them pick up the impact gun. Twice now I've tapped the guy about to put my wheel on using one and asked him if I could do it myself to save the studs from shearing at speed. Both times I've received a very confused look from them. I'm definitely going to be present when the wheels go back on this time. just hope it didn't effect anything else. Quote Link to comment Share on other sites More sharing options...
merckx Posted December 6, 2011 Share Posted December 6, 2011 looking at £130 fitted as im using Toyota Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 That's actually not bad for a Toyota quote. I found the rear studs quite footery to get to, took a little bit of time. With the going rate at MrT £100+vat that's not half bad Quote Link to comment Share on other sites More sharing options...
merckx Posted December 6, 2011 Share Posted December 6, 2011 I found the rear studs quite footery to get to, took a little bit of time. Yes, easier on the front. I replaced all the studs myself and I don't trust anyone to remove the wheels. Quote Link to comment Share on other sites More sharing options...
jim Posted December 7, 2011 Share Posted December 7, 2011 £130's shocking - iirc the bolts cost £4 each. I had extended studs fitted within the past couple of months and the job took my mechanic half an hour max. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 7, 2011 Share Posted December 7, 2011 £130's shocking - iirc the bolts cost £4 each. I had extended studs fitted within the past couple of months and the job took my mechanic half an hour max. That's good going if it was the rears Quote Link to comment Share on other sites More sharing options...
jim Posted December 7, 2011 Share Posted December 7, 2011 That was just one hub Scott, but yep it was a rear. Quote Link to comment Share on other sites More sharing options...
fastcar Posted December 8, 2011 Share Posted December 8, 2011 this is the main reason why i do all the work on my car myself. Most mechanics charge the earth and cant even do the job right. There is only a very few that can be trusted to do a good job. Quote Link to comment Share on other sites More sharing options...
