a98pmalcolm Posted December 6, 2011 Share Posted December 6, 2011 Hi all. Ok nightmare day wiring up heated windscreen. For some reason the 30amp fuse between the battery and the relay is getting VERY HOT when the screen is activated. It worked perfectly but heat issues within the wiring are worrying? Should I put the fuse between the replay and heated screen instead? I Have attached a picture is anyone cant help. Thanks Paul http://img685.imageshack.us/img685/9458/wiringz.jpg Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 What gauge of wire are you using? The heat would suggest impedance in the circuit. The most likely suspect for this is thin wire not suitable for 30 amps. Quote Link to comment Share on other sites More sharing options...
d_d Posted December 6, 2011 Share Posted December 6, 2011 You sure its a 30 amp fuse, maybe its on the limit and getting very hot. Quote Link to comment Share on other sites More sharing options...
heckler Posted December 6, 2011 Share Posted December 6, 2011 Just emailed you. wired up wrong dude. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 Just looked at the actual diagram there.... snot half lmfao. I doubt your battery would be lasting long either Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 6, 2011 Author Share Posted December 6, 2011 snot half? lol Quote Link to comment Share on other sites More sharing options...
Marty Posted December 6, 2011 Share Posted December 6, 2011 Nice wiring Do you know how to wire it up properly now mate? Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 snot half? lol Snot half = it's not half Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 6, 2011 Author Share Posted December 6, 2011 Yer heckler has been so so helpful drawn up a diagram how its meant to be done and the wire i have used isn'y good enough. Paul Whifin also tells me it needs 2 relays. So looks like I gotts strip the whole dam lot out and start again.. I'v wasted so much money in wiring that I thought would be good enough. And the time this has taken... Quote Link to comment Share on other sites More sharing options...
Scott Posted December 6, 2011 Share Posted December 6, 2011 What rating is the relay you are using? You should be able to get away with one if it's big enough and the cable you use is big enough. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 13, 2011 Author Share Posted December 13, 2011 New problem.. All rewired and cables aren't getting hot neither is the fuse, just warm, but the battery went completely flat after 45 mins of it being turned off with one for the relays buzzing.. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 13, 2011 Share Posted December 13, 2011 Could be a faulty relay but I would suggest you take it to someone who knows what they are doing bud. I'm all for "have a go" but your initial attempt at this shows that you don't really know what you are doing. Last thing I want to read is your car being on fire, or worse. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 14, 2011 Share Posted December 14, 2011 Just tape the wiring to the screen. Sorted.... They draw a LOT of current, you need decent connections and decent cable, and a proper (probably none Ebay) relay of good conservative amperage rating. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 16, 2011 Author Share Posted December 16, 2011 Getting there slowly guys. Using 35amp wire 30 amp fuses 30 amp relays Just need to sort out the switch correctly as i'm an active spoiler switch to keep an OEM look and then hay presto! should be all done Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 16, 2011 Share Posted December 16, 2011 That should handle it, don't have it so you can accidentally leave it on with the engine not running, the battery will be flat in no time. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 16, 2011 Author Share Posted December 16, 2011 Oh i know that chris!! When I wired the switch up 1st time it left the current running 45 mins or so when i returned to the car DEAD!! couldn't even run an interior light lol Quote Link to comment Share on other sites More sharing options...
