Welshbuddy's Supra Build, Engine Conversion++ with videos.
welshbuddy
  • Replies 256
Posted Images
Update: Got a nice little prezzie when i got home from work :).
my 60-1turbo :), polished.
4" k&n air filter with hardpipe.
46mm wastegate with screamer pipe.
cracked on.
connected oil feed+ return.
test to see if it colides with anything in the engine bay.
Couple of waterpipes will need blocking off in the engine bay.
The wastegate is pretty close to the steering column, but is good :D
My new Boostlogic 4" exhaust.
next to my 2.5" decat haa
3" downpipe or 4" :) lol
Edited by welshbuddy (see edit history)
List of things recieved
manifold
turbo 60-1. 58.ar
oil lines/return
K&N 4" air filter.
46mm wastegate
screamer pipe
3"Downpipe with clamp
New genuine oil pump
New crank pulley bolt.
Denso 255lp/h fuel pump.
Whole gasket kit for the 1jz.-
will be stripping all down replacing all seals. inc valve stems.
got my new Radiator through!
its a stoney radiator off ebay, yeh off ebay.
he lives right by me and offered me a ex display one for 100quid delivered in person (which i thought was cool and a good price! also a top lad.)
Heres some photos of it - the quality is better than i expected!
55mm 2 core radiator.
plus got a 1.1bar radiator cap :).
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=156893&d=1346182108
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=156895&d=1346182130
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=156894&d=1346182119
Got to polish up the top part of the rad mate:) what exhaust manifold and downpipe are you using?
ill get it gleaming, ;).
Exhaust manifold is a Driftmotion and the downpipe is.
Iv never heard bad things about driftmotion , did alot of research before i used them and to be honest there a mint company.
Contact you about everything, shipping took 3 days from the USA!
the downpipe, i need to find a different bung and weld it on for the o2 sensor as it is a different fitting.
Hopefully the rad is a good fit mate. If so, linky link?
will be fitting it this week mate and i will let you know :).
the lad i bought it off is from here so any problems i can get cash back, i also bought a set of there hoses, which are on the car now.
cant fault them at 30quid! saving of 50quid from samco ha.
