LSD set up
antno
Recently bought a tt6 and the rear end was solid. No slip in the diff what so ever. I thought it could of been welded up as the car could possibly have been drifted back in Japan.
Anyway pulled the diff housing out n popped the back off and I think it's a carbonetic diff but il find out more when I get it to work and have a look at the plate pack.
What I want to know is how much preload do you normally run? I'm a novice driver so I suspect something quite low 50nm or something. I'm going to use it for trackdays n just general road use so I want it to go round bends.
Also the ramp angle seem to be about 30/30 which would be nice and progressive. Has any one tested different angle for braking and acceleration?
Cheers antno
The preload is just too high unless the diffs broken. Some one has put extra bevel washer in or increased the number of friction faces to the maximum or they have increased the plate pack height. I can reduce the friction faces by putting the outer spined plates together. We use kaaz diffs at work so Ive got plenty of oil to throw at it. Another question. Has any one had a carbonetic diff apart? Do they usually have a choice of ramp angles?
Cheers antno
  • 2 weeks later...
so i stripped the diff and found nothing wrong with the internals. think the diff is actually a kaaz as its very similar. i think it could have possably have had the wrong oil in. the preload on the bench when cold was only 50nm but i think that when the oil gets hot it goes too thin and the preload goes much higher, which is whats causing the solid rear axle. the diff was set to its full friction face setting of 16ff. i rebuilt the diff with kaaz oil to the same set up as it came out of the car and got 110nm of preload so i think it was set up for drifting or drag racing or possibly a competent driver. ive decided to run it at 8ff with a preload of 60nm(second photo in) so its a bit more progressive and better around bends.
if anyone thinks its another diff please let me know
figures i got with kazz oil
16ff 110nm
12ff 85nm
8ff 60nm
4ff 35nm
Edited by antno (see edit history)
It's a 2 way diff and not adjustable (some types have a body section you can turn though about 30 degrees and bring a none equal set of ramp angles into play, to give "1.5 way". Using decent oil will help, best oil is the OS Giken stuff, or Neo, but both are *WHOA, how much....????!!!!" expensive. Next best is Castrol LSD oil with Chrylser Cherokee Jeep friction modifier added, the modifier is available from any Chrylsler dealer in small bottles. The Castrol oil I think is still available from Demon Tweeks, from memory it's 737 or 747 type. I can check, there's a gallon in the workshop for older cars. Put two or three bottles of the additive in. Very best is bin it an fit a Giken LSD section :) It'll be awful on a track with those ramp angles.
I have a fair understanding off setting up diffs was just wondering on the preload on the plate pack that's all.
I work for a small rally team and do the odd race car. I mainly build engines but the other guy in the gearbox shop has been building compotition boxes for years. Started at prodrive on the wrc legaceys then the imprezas. So he's always there to help but he's never had anything to do with supras
We do porsches and we run a kaaz diff with 40nm of preload on the pack and 60/45 ramp angles. 60 under acceleration and 45 under breaking.
This is quite soft and progressive but it is for gravel and rear engine and rear wheels drive so can't really use anything we've learnt testing that on the supras as it's not ending up in the forest. For road/trackday novice drivers we halve the preload again so it's even less grabby. Some factory race cars used to use spools instead. Possible due to the diffs shearing I don't know.
We found the kaaz diff doesnt need massive preload well not for a Porsche.
Also have you tested with the kaaz oil?
We couldn't as our diffs are in the gearbox so we have to use an oil compatable with syncros.
Do you think the 30/30 ramp angles are a bit too flat?
Would you stay 2 way with 45/45 or 1.5 way and run a 60/45 or something?
Also what way would you have the ramp angles flatter under breaking or acceleration?
Cheers for your time
antno
