Indicators/hazards faulty
ADD
Evening all
The last few times i have used the supra ive noticed when i use either the indicators or hazards they work fine for a few seconds then stick on (indicators lit). When the stalk is disengaged the indicator clears but then sticks on again when they are required. Im going to have a look at the 'Flasher unit' and 'Flasher Relay' first, can anyone suggest anything else i should do?
There is no burning smells or funny noises (arching/shorts)
cheers
Add
Evening all
cheers
Add
Sounds like the flasher relay/unit (same thing) is on its way out. It's a 3 pin relay in the drivers side foot well.
