uk limiter
Rob Moch
Guest Martin F
On a manual that is the only thing it does, removes the 155mph limit.
On an auto there is some speculation as to whether removing this fuse also defeat's the closing of the throttle when the auto box changes gear.
I'm not sure if this has been proven one way or another.
Quote: from Martin F on 9:14 am on Mar. 1, 2002[br]On a manual that is the only thing it does, removes the 155mph limit.
Cheers for that info Martin.
Guest Martin F
Just to clarify it does switch off the traction control system as well.
I was ASS-U-MING that people would realise that as it is called the trac fuse.
Guest Martin F
Quote: from Flipfinger on 10:13 am on Mar. 1, 2002[br]I don't have a TRAC fuse........what can I do?
1,000 posts, woohoo!
Go easy with your right foot :biggrin:
