Rob_Mitchell Posted January 8, 2012 Share Posted January 8, 2012 Slowly getting there. Looks good Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted January 8, 2012 Share Posted January 8, 2012 sweet mate ! , looks alot cleaner! Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 8, 2012 Share Posted January 8, 2012 Just a quick question, but do you have to drain anything to get the turbo pipes off? or is it all just vacuum pipes? Going to start doing mine over the next few days so any info would be great. Never stripped either side down before so have no idea what to look out for of what might be a pita of a job to do. Quote Link to comment Share on other sites More sharing options...
Lude Posted January 8, 2012 Author Share Posted January 8, 2012 its not a pain in the arse job really mate, read the guide i posted so you know where all the bolts are. when you do the turbo side there is nothing to drain, its all air and vacuums. there are 2 pipes though with water in, but you dont need to remove them for the turbo pipes or even the heat sheild. these are the 2 im refering to... on the other side (manifold) there are 2 pipes which go to the throttle body, underneath. these both have water in. when you remove only a small amount will come out, just plug them up so you dont lose much water. also when/if you remove the idle valve, there are 2 pipes which go to the valve which have water in. you can remove the valve though and just leave the water pipes connected. as it was off tho i gave mine a clean. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 8, 2012 Share Posted January 8, 2012 No nothing needs to drain to take them off just make sure the engine hasn't been run for a few hours as it can be a bit hot! EDIT - Lude beat me to it there Great thread by the way I've been watching this with interest as I plan on doing similar Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted January 8, 2012 Share Posted January 8, 2012 had a few people PM'ing me about the sizes of the stock pipes here http://i181.photobucket.com/albums/x169/lude200/IMG00166.jpg one is 50mm diameter by 120mm length, the other two are the same size, both 58mm diameter by 80mm length. just search ebay silicone hoses and there are plenty of people who make them up Great stuff. Might do this later in the week. Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 20, 2012 Share Posted January 20, 2012 Had a go at this today Mate, thanks for all the links and advice about the Vac lines etc, was a bit of a pita to get out though, could'nt get to undo the last few hard pipes that run along the top, so ended up leaving them in place while i got the turbo hard pipes and the heat shield out. Just got to give them a good refresh now. Quote Link to comment Share on other sites More sharing options...
Lude Posted January 20, 2012 Author Share Posted January 20, 2012 yea i think i know which ones you mean, the ones that go down to the back of the engine yea? i left those too, and just cut the hardpipe with a hacksaw, then used silicone vacuums instead and hid them away. il post an update tomo, as ive done a custom intake so happy with it, check out the thread tomo evening Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 20, 2012 Share Posted January 20, 2012 I was thinking of doing the same thing. As long as you re connect everything back up the same way i cant see it making any difference. Do you know what size vac hose is needed to replace everything? I think most are around 4-6 mm? edit, Yeah the ones that went down the back between the turbo and firewall. Quote Link to comment Share on other sites More sharing options...
Lude Posted January 20, 2012 Author Share Posted January 20, 2012 Do you know what size vac hose is needed to replace everything? I think most are around 4-6 mm correct mate, i had some 4mm vacuum, and some 6mm vacuum. i had 2 metres of each, more than enough. always keeps as spare as itl get used at one point in your life lol get the vacuums on ebay only a couple of quid literally Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 20, 2012 Share Posted January 20, 2012 Cool ill have a look now, if you cut out all the hard pipe vacuum lines then you must of had to add a few T's aswell? Looking near the back, some of the lines go off to more than one place, best get me some T's aswell me thinks Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 20, 2012 Share Posted January 20, 2012 [COOL][/COOL]Well done mate, a massive improvement for relatively little outlay Just out of interest, has anyone ever shot blasted the turbo pipes before? Quote Link to comment Share on other sites More sharing options...
Lude Posted January 21, 2012 Author Share Posted January 21, 2012 (edited) update today got a tidy camera, as my blackberry is just crap. put my custom intake together, as the stock rubber black on didnt really go 1st got some pipe from ebay, was perfect 76mm at one end, then tapers out to 85mm or so at the other end, like the stock does cut it down to size and sprayed then had some more samcos cleaned and sprayed the APexi "induction kit" put it all together and fitted de-greased parts of the engine bay, will do it all and spend more time, just did some while i had the PAS resivour & ignitor pack off before and also did the firewall (removed the sound proofing too) tomorrow going to bleed the PAS (hope ive sorted my pump leek, as stripped pump and put new gaskets in last week) then fit the intercooler pipe and done ive got the blue strut braces off and the cusco brake stopper, not suer of blue goes with it all? or shall i do it blackor yellow? Edited January 21, 2012 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted January 21, 2012 Share Posted January 21, 2012 Looks great mate with all the vac lines out the way. How have you tucked them out of site? just curious as there is alot of heat around that area. Quote Link to comment Share on other sites More sharing options...
Lude Posted January 21, 2012 Author Share Posted January 21, 2012 a lot of my vacuums are not used. i only have one vacuum which runs underneath the turbo pipes. the rest are jsut blocked off/not needed, as the carbon canister is deleted, i have a electronic boost controller, stock bov is removed, so you dont need all of them. look at the earlier pages ive colour coded the vacum hard pipes to show whats what Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted January 22, 2012 Share Posted January 22, 2012 looking good, need to remove the vac hard pipes from mine when I get it back Quote Link to comment Share on other sites More sharing options...
Lude Posted February 12, 2012 Author Share Posted February 12, 2012 thought id post these to finish off the thread sorted out the colour co-ordination, removed the strut brace cleaned and primered sprayed and all together real happy with how clean it all looks under there. the PAS resivour, intake manifold, the firewall, intercooler. taken bloody ages Quote Link to comment Share on other sites More sharing options...
ashbuster Posted February 12, 2012 Share Posted February 12, 2012 looking good mate alot cleaner Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 12, 2012 Share Posted February 12, 2012 very nice. looks like you ruined that leather sofer though! Quote Link to comment Share on other sites More sharing options...
Lude Posted February 12, 2012 Author Share Posted February 12, 2012 very nice. looks like you ruined that leather sofer though! il turn the cushion over thanks for comments Quote Link to comment Share on other sites More sharing options...
marc_p Posted February 12, 2012 Share Posted February 12, 2012 Wow, that Supe actually looks perfect, nice to see more people sticking with stock lines Quote Link to comment Share on other sites More sharing options...
DaveR Posted September 15, 2012 Share Posted September 15, 2012 Bit of a resurrection of an old thread this (), but I've only just seen it and felt I had to comment! Basically, nice one! I really admire the talent / patience. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 16, 2012 Share Posted September 16, 2012 much nicer mate Quote Link to comment Share on other sites More sharing options...
