hodge Posted November 23, 2011 Share Posted November 23, 2011 I'm going to fit an extra fuel pressure sensor for my Syvecs. Can I fit the sensor in the fuel feed line? Cheers John Quote Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Share Posted November 23, 2011 Can you not tap it into the rail? If not there are end fittings for the rails that you can put sensors into. It would just pull your line out slightly. Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Author Share Posted November 23, 2011 Can you not tap it into the rail? If not there are end fittings for the rails that you can put sensors into. It would just pull your line out slightly. That would just be far too untidy Quote Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Share Posted November 23, 2011 You can probably get a Y piece for the top of the FPR if that's any good? You could even replace the FPR gauge with the sensor, not really much use once it's set if you are monitoring via the ECU. Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 23, 2011 Share Posted November 23, 2011 Ideal would be after the rail (to see rail pressure drop) but before the regulator. Don't put it after the regulator, though. Fit this inline and screw the 1/8NPT in it, IIRC Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Author Share Posted November 23, 2011 The regulator "should pressurize the whole system inc the feed line. I don't want it in view, that would be sacrilege. I'm sure I've seen them fitted in the feed line before the rail. Quote Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Share Posted November 23, 2011 The regulator "should pressurize the whole system inc the feed line. I don't want it in view, that would be sacrilege. I'm sure I've seen them fitted in the feed line before the rail. Have it fitted pointing downards out of the way so it can't be seen Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Author Share Posted November 23, 2011 Have it fitted pointing downards out of the way so it can't be seen But I know it's there and that's an extra 2 wires into the bay and that's clutter under the plenum. I know I'm being rediculous but needs must. I'm not sacrificing what I've already created for compromise now. Quote Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Share Posted November 23, 2011 But I know it's there and that's an extra 2 wires into the bay and that's clutter under the plenum. I know I'm being rediculous but needs must. I'm not sacrificing what I've already created for compromise now. It's going to have to be in the bay one way or another though as it will be between the FPR and the fuel rail. Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 23, 2011 Share Posted November 23, 2011 Could you tap the rail for a 1/8NPT feed and run from there? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Share Posted November 23, 2011 Could you tap the rail for a 1/8NPT feed and run from there? My suggestion of that was already dismissed Quote Link to comment Share on other sites More sharing options...
johnny g Posted November 23, 2011 Share Posted November 23, 2011 (edited) He's got it in his mind now that it won't be there. Expect to find it in the rooflining or something Edited November 23, 2011 by johnny g (see edit history) Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Author Share Posted November 23, 2011 I'm going to run a -10AN fuel line and run it from where the fuel filter is. Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Author Share Posted November 23, 2011 Going to use 1 of these. http://www.ebay.co.uk/itm/150699261870?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_771wt_689 Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 24, 2011 Share Posted November 24, 2011 What FPR are you running? Im sticking mine in my Aeromotive FPR, its got an extra port. Quote Link to comment Share on other sites More sharing options...
hodge Posted November 24, 2011 Author Share Posted November 24, 2011 What FPR are you running? Im sticking mine in my Aeromotive FPR, its got an extra port. I've already got my Defi sensor in there. Ive just spoke to Ryan and he said it would work ok in the line so I'll just go for that. Cheers John Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2011 Share Posted November 24, 2011 Pressure sensors are best in the fuel line, they don't much like vibration and heat. In general they can be a bit unreliable fitted straight into the block (say for oil pressure) or straight into the fuel rail. I tend to fit them away from the engine on -3 hose. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 24, 2011 Share Posted November 24, 2011 Can the Defi sensor not be tapped into and the signal supplied to the Syvecs? Quote Link to comment Share on other sites More sharing options...
hodge Posted November 24, 2011 Author Share Posted November 24, 2011 Pressure sensors are best in the fuel line, they don't much like vibration and heat. In general they can be a bit unreliable fitted straight into the block (say for oil pressure) or straight into the fuel rail. I tend to fit them away from the engine on -3 hose. Great stuff, thanks Chris into the fuel line it goes then. You've just saved me 2 extra wires in my engine bay, which makes me smile Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 24, 2011 Share Posted November 24, 2011 I have probably saved you 3 wires, which is what most pressure sensors have (5 volts, ground and signal). Quote Link to comment Share on other sites More sharing options...
hodge Posted November 24, 2011 Author Share Posted November 24, 2011 I have probably saved you 3 wires, which is what most pressure sensors have (5 volts, ground and signal). Correction noted and understood Quote Link to comment Share on other sites More sharing options...
