Ps3 + Router Help Required Please
Marty
So i've got myself a new ps3, and have set it up in my front room, it is wired to the router.
I decided to give the ps3 a quick blast, on black ops, first game was ok, bit laggy, then i had connection problems, the ps3 kept saying the connection had been cut and dropped me out of the games, it was also a challenge to find any game lobbies to join i noticed.
I've done a bit of a search on google and found a few people who have had similar issues and its down to the router and ports or something, but i've not found any definitive answers that a non IT man could fix :)
The router is a Belkin n300 like this ... http://direct.tesco.com/q/R.209-8187.aspx
Has any one experienced anything similar when they've upgraded their router and tried gaming? And if so, whats the easiest fix? :)
My pc is also wired to the router and i experience no issues whatsoever with it, so its defiantly a ps3 - router issue.
Muchas gracias in advance
The easiest fix is to remove the firewall between your PS3 and the router. If you want to do this simply setup your PS3 with a static IP. To do that you go into network, network settings and then select "custom" rather than easy. Leave everything as default other than the IP and the other settings on the same page.
If your Router IP is 192.168.1.1 then setup your PS3 with the following...
IP - 192.168.1.200
subnet - 255.255.255.0
Default Gateway - 192.168.1.1
DNS Server - 192.168.1.1
Firstly, see if the above helps you. If it doesn't, connect to your router via your PC browser (192.168.1.1 eg). Look for security settings and more specifically firewall. See if there is a DMZ option, if there is type in the IP address you just set your PS3 with and apply the settings... give it another go.
If you don't have the DMZ option you can turn off your firewall altogether. I would only do this as a test though, to see if it solves your issues. Once you have determined that it does or doesn't, turn it back on. If it solves your issues you need to find which ports are in use and forward them to the PS3 IP.
Go to 'Internet settings' and then 'Internet connection test' if you have a wired connection you should have a NAT Type of 1. As far as I know you only need to open the ports if your using a LAN connection.
cool, i'll forget about all that port stuff then :)
My ps3 says NAT Type 2?
Could that be something to do with the issue?
IP - 192.168.1.200
Super, thanks for putting the effort in to write that Scott it's much appreciated. I'll take a look at all that now and report back how i get on, i think i can work out how to do all that :)
I think i should shave stuck with my o2 router ...
  • 2 weeks later...
Thanks buddy :thumbs:
What router do you have? Make sure uPNP is turned on. That will allow the PS3 to connect directly. Make sure uPNP is turned on both on your router and your PS3.
It's a belkin N type router, the uPNP was turned on.
After fiddling around with it, and the ip addresses etc it seems to be behaving itself now, i've managed to dish out plenty lead butties to cyber soldiers without a single disconnection :)
So hopefully all sorted now, thanks for the help guys, as always, it's much appreciated :)
