dr_jekyll Posted November 21, 2011 Share Posted November 21, 2011 ive got a strange fault with my laptop. for some reason the "enter/down line" key is not performing it usual function. it just does the same as the right click button. i cant down to make a new paragraph or enter passwords . driving me mad. any possible ideas? Link to comment Share on other sites More sharing options...
The-Plethora Posted November 21, 2011 Share Posted November 21, 2011 Have you got the language bar open on the taskbar? also is your keyboard set to UK in control panel? Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 21, 2011 Author Share Posted November 21, 2011 no language bar and seu to english uk ? Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 23, 2011 Author Share Posted November 23, 2011 bump Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 25, 2011 Author Share Posted November 25, 2011 ok so we cleaerly have no laptop techies in ,..... but is there any other way of going down a line by using other buttons, e.g shift control ect Link to comment Share on other sites More sharing options...
Abz Posted November 25, 2011 Share Posted November 25, 2011 ok so we cleaerly have no laptop techies in ,..... but is there any other way of going down a line by using other buttons, e.g shift control ect Craig, Quite a long winded way but you could use the 'Tab' key (the right above caps lock with the two arrows pointing each way). You could also keep pressing the space bar until it goes down where you need it going. Strange what is does, have you tried disconnecting the laptop battery & live it out for 15 minutes or so & then reconnect again? Check keyboard settings by going to Control Panel (presume you are using Windows). Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 25, 2011 Author Share Posted November 25, 2011 yea ive tryed the controll panel . and the disconection, also tryed a full system restor to factory settig but still the same . what should the tab key do? Link to comment Share on other sites More sharing options...
Graham1984 Posted November 25, 2011 Share Posted November 25, 2011 Is there no way you can go on the keyboard settings and change the config to use a differant key for that instead?? Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 25, 2011 Author Share Posted November 25, 2011 Is there no way you can go on the keyboard settings and change the config to use a differant key for that instead?? i dont know? is there ? Link to comment Share on other sites More sharing options...
Scott Posted November 25, 2011 Share Posted November 25, 2011 Did you spill anything on the keyboard or anything like that? Did it just start happening? Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 25, 2011 Author Share Posted November 25, 2011 just happend as far as im aware , unless the mrs spilt something on it but knowone is owning up. if it was a spill is it fubard? Link to comment Share on other sites More sharing options...
Graham1984 Posted November 25, 2011 Share Posted November 25, 2011 Click the windows/start button on the bottom left and type in "keyboard" in the search programmes and files box and the keyboar options should be in there. You should be able to change the standard setup to a custom one but obviously you only want to change the enter key to something else so just use any key that you never use or alternatively if you have a separate number panel of 1-9 numbers to the right of your enter key and not the ones under F1-F12 you should have another enter key on their anyway. Link to comment Share on other sites More sharing options...
