Scott Posted November 21, 2011 Share Posted November 21, 2011 I'm looking to do something a little different with my boot build so my current one is now up for grabs. Unfortunately this thing weighs a fair bit so I'm thinking it would be collection only unless someone knows a way I can send it safely. If I don't get any interest in the whole lot I'll be happy to split everything up and sell individually, in which case postage of most items should be no bother. The build consists of the following: 10" Solo Baric L5 Subwoofer - 450W RMS Kenwood KAC-8104D Mono Amplifier - 300W RMS @ 4 Ohms (500W @ 2 Ohms) Kenwood KAC-8404 4Ch Amplifier - 4x50W RMS @ 4 Ohms (4x75W @ 2 Ohms) Kenwood KAC-7204 2Ch Amplifier - 2x170W RMS @ 4 Ohms (2x250W @ 2 Ohms) Vibe QB69 6x9's - 2x200W RMS Custom Built Amp Rack with perspex & Vinyl Supra Stickers & logo. Custom Built Sub Box Ported with correct volume. http://www.mkivsuprastar.com/Pics/Ice%20Install/Now/DSCF1778.JPG http://www.mkivsuprastar.com/Pics/Ice%20Install/Now/DSCF1779.JPG http://www.mkivsuprastar.com/Pics/Ice%20Install/Now/DSCF1781.JPG http://www.mkivsuprastar.com/Pics/Ice%20Install/Now/DSCF1803.JPG http://www.mkivsuprastar.com/Pics/Ice%20Install/Now/IMG_6448-1000.jpg I'm after £500 for the lot. It will slot straight into an empty supra boot with absolutely no modifications. The only thing that needs done is the boot blind hooks unscrewed. The spare wheel, tools etc remain untouched. Also the boxes have handles on them so that if you should need to remove them, you can quite easily (for access to the spare etc). This setup has seen next to no use since new (I would guess around 10 hours total). I have all the boxes for all the different bits and bobs, along with all the manuals etc. Individual prices should the time come to split: 10" Solo Baric L5 Subwoofer - 450W RMS - £120 posted Kenwood KAC-8104D Mono Amplifier - 300W RMS @ 4 Ohms (500W @ 2 Ohms) - £80 posted Kenwood KAC-8404 4Ch Amplifier - 4x50W RMS @ 4 Ohms (4x75W @ 2 Ohms) - £100 posted Kenwood KAC-7204 2Ch Amplifier - 2x170W RMS @ 4 Ohms (2x250W @ 2 Ohms) - £100 posted Vibe QB69 6x9's - 2x200W RMS - £70 posted Custom Built Amp Rack with perspex & Vinyl Supra Stickers & logo. £50 Custom Built Sub Box Ported with correct volume. £50 I'm willing to listen to offers on anything and everything but please refrain from daft ones Link to comment Share on other sites More sharing options...
RobUK Posted November 22, 2011 Share Posted November 22, 2011 If the boot junk was removed would it sit low enough to allow an Aerotop roof? Or would it require alot of modification? Link to comment Share on other sites More sharing options...
Scott Posted November 22, 2011 Author Share Posted November 22, 2011 If the boot junk was removed would it sit low enough to allow an Aerotop roof? Or would it require alot of modification? It would definitely still require modification unfortunately. Even with everything in the boot removed I don't think the level height actually changes. You might gain an inch or so but definitely not enough for the roof to get in there. The underside of the amp rack is 1 flat piece almost the same dimensions as the top half. The bottom of the sub box is around half the width and the same depth as the top panel. The 6x9 speakers are free air, the box edges are just inside where the 6x9s are. Just to give an idea of what it's like on the underside. Link to comment Share on other sites More sharing options...
Guest stevebratcher Posted November 23, 2011 Share Posted November 23, 2011 Pm'd Link to comment Share on other sites More sharing options...
The Raven Posted November 23, 2011 Share Posted November 23, 2011 IMO that would never fit in an aero boot. The roof sits way to low. I wish i had a non aero sometimes. The amount of hassle this would save on an install is worth the £500 alone. GLWTS Link to comment Share on other sites More sharing options...
Xzarik Posted November 23, 2011 Share Posted November 23, 2011 You have no idea how tempted I am by this... But no. I need a boot! Link to comment Share on other sites More sharing options...
Scott Posted November 23, 2011 Author Share Posted November 23, 2011 You have no idea how tempted I am by this... But no. I need a boot! The way I have mine setup I can remove it in about 1 min flat Can easily show you how to do the same Link to comment Share on other sites More sharing options...
