Guest ugp Posted November 21, 2011 Share Posted November 21, 2011 Nope, pads fall out of the bottom. Quote Link to comment Share on other sites More sharing options...
Dnk Posted November 21, 2011 Share Posted November 21, 2011 (edited) The pads will only come out the bottom if you unbolt the caliper, i think you need to have another look and take a pic of the caliper from the side and post it up to show the heads of the pins. The tabs in blue stop the pads from coming out the bottom or they'd hit the disc ! Edited November 21, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 21, 2011 Share Posted November 21, 2011 I would expect as dnk says, for the "pins" to be two cap head Allen bolts. You shouldn't have to remove the calipers to change the pads. Have you asked Paul Whiffin if this is play normal? Or rung KAD? Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 21, 2011 Share Posted November 21, 2011 Pads definitely don't come out the top, they're too big. Looks like them pins may come off though, looking at the caliper they've never been removed before. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=130477&d=1302857926 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 21, 2011 Share Posted November 21, 2011 (edited) The bridging pieces on the top calipers, and the two tubes on the lower ones should have Allen bolts through them, remove the bolts and the bridges should come out, they are to hold the pads in and stiffen the caliper against lateral expansion. You can see the "joints" in the video. I would be alarmed if KAD say they are the correct pads, or no abutments are missing... Edited November 21, 2011 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 21, 2011 Share Posted November 21, 2011 Ah I see, they've never been removed before, the paint is perfect over the joins. I've pm'd Paul Whiffin, hopefully he can shed some light on the issue. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 21, 2011 Share Posted November 21, 2011 This thread any help? Are these the same pads as you have? http://www.mkivsupra.net/vbb/showthread.php?165511-KAD-6-pot-pad-recommendations Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 21, 2011 Share Posted November 21, 2011 we have had cars in here with k-sport and KAD and D2 and never seen this before so a bit of the kit is missing or wrong pads k-sport - suprafans car d2 - my old rx7 KAD - customers supra Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 21, 2011 Share Posted November 21, 2011 http://www.kad-uk.com/forum/viewtopic.php?f=25&t=51 Hmmmm. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 21, 2011 Share Posted November 21, 2011 http://www.kad-uk.com/forum/viewtopic.php?f=25&t=51 Hmmmm. Oh great. Thanks for that Chris! I'm not surprised a pad was misplaced with the amount of movement in these! I shall get on the trumpet to KAD this afternoon and see what they have to say. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 21, 2011 Share Posted November 21, 2011 This thread any help? Are these the same pads as you have? http://www.mkivsupra.net/vbb/showthread.php?165511-KAD-6-pot-pad-recommendations Yep, those look identical. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted November 21, 2011 Share Posted November 21, 2011 Do phone Paul Whiffin. SteveL uses Kads on his race car and they know them well. He will also be able to get you some decent pads;-) Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 22, 2011 Share Posted November 22, 2011 I have spoken to Paul today regarding these, it would appear I have the original set of pads that KAD supplied with these, and there were some that had the wrong size pads supplied, which appears to be the problem I'm having. Paul will be trying to sort me some new pads when I get the measurements and drawings over. Quote Link to comment Share on other sites More sharing options...
l.chris97 Posted November 26, 2011 Share Posted November 26, 2011 (edited) Sorry guys i posted on this thread by mistake ment to start a new thread Edited November 26, 2011 by l.chris97 (see edit history) Quote Link to comment Share on other sites More sharing options...
