anti roll bars & bushes
crispy
Nic...how stiff are these vs the Titan ARBs!?
I've no experience of the US made Titan ARB's, but this is how they compare to the stock ARB's.
Cusco ARB
Front 153% stiffer than stock ARB.
Rear is adjustable, either 240% or 297% stiffer compared to stock ARB.
Cusco ARB
Checked on google mate...numbers you stated seem to be ratio with standard
Meaning the
fronts are 53% stiffer than stock and
rears are 140-197% stiffer than stock.
That sounds alot on the rear!?
Stats as stated by you on here in 2005 direct from the Cusco website:
Front(32mm Hollow bar)
The kit includes 2 bushings, and need apprx.1 hour for installation.
Stiffness: 153% against Factory 30mm hollow bar.
Rear(22mm Solid bar)
Stiffness: 2way Adjustable, 240%/297% against Factory 19.2mm hollow bar.
So don't think I am arguing...just surprised at the numbers!?
The TRD's are stiff enough so god knows how stiff these others
must be if your figures above are correct, seems very high to me and
my car with the TRD's on it has hardly any roll
According to Whifbitz the TRD's are 27% stiffer than stock.
Titan figures from Whifbitz site
Front Sway Bar (2 way adjustable)
Light Setting 8% stiffer then TRD 498.9 lbs/in
Heavy Setting 27% stiffer than TRD 584 lbs/in
Rear Sway Bar (3 way adjustable)
Light 18% softer then TRD 367 lbs/in
Medium 6% Stiffer than TRD 458 lbs/in
Heavy 35% Stiffer than TRD 588 lbs/in
ok and any one uprated there cars front & rear bushes?
The ball joints are an integral part of the arms and cannot easily be replaced separately, you'll get better results replacing with brand new OEM arms. Do a search in the Tech section and you'll find a lot of threads on the subject.
It's a comparison of the stock ARB stiffness expressed as a
percentage
ie. if the stock front ARB is 392 lbs/in, the Cusco front ARB is 392 x 153% = 600 lbs/in
Details taken from the Cusco website
HERE
percentage
HERE
I understand that Nic. Thanks for the link.:)
Out of interest how much are the Cusco ARBs delivered to the UK!?
