is my gauge sitting right?
ashbuster
hey guys
ive had a few probs with this cheap gauge i bought £50 ebay
mainly the connections on the back of the gauge
anyway sometimes the gauge turns on when i start the engine then drops right to the bottom
but now i got it working its sitting about here in park
http://s998.photobucket.com/albums/af103/ashbuster/?action=view&current=Video0014.mp4
heres a little vid
reason im asking is to make sure the gauge is ok now or needs sending back
also i have a jap spec which is decatted and i thought it sends it way over 1 bar and i thought you needed a boost controller to lower the boost
and i have no boost controller at all on it, and no fuel cut defender
any reasons why it hasnt gone above 1 bar with the decat?
thanks guys :)
not sure mate havent been under the car and too dark now i know there isnt one in the middle anywhere
i didnt realize these had 2 cats
when i bought it in the listing on here it said chris wilson decat
i take it that theres a restrictor ring thats limiting it to 1 bar?
and to increase this i just buy a manual boost controller and fcd
Edited by ashbuster (see edit history)
There is the first cat from the turbos, and then another cat a bit further down the exhaust. You should be able to tell if its a decat by looking just after the second Turbo. If its a straight pipe, its a decat, if it looks like an exhaust silencer (kind of), its a cat. As I say, with my first cat still in, just after the second Turbo, it would only make 1 bar. That was with a second decat as well.
I'd buy a Fuel Cut Defender anyway, just to be sure. If funds allow, an electronic boost controller is best I believe, although the manual ones are OK. I'm happy enough with mine as is though! No boost controller fitted!
nice one mate thanks for that pik
if it does have a restrictor ring to 1 bar then to increase it i can do it with a manual boost controller and fcd carnt i mate? or would that restrictor ring have to be removed first?
Pretty sure with a boost controller you could do, you need a fuel cut defender so it doesn't hit fuel cut over 1 bar; I'd email Chris Wilson to be safe though. The restrictor ring is best left in place so you don't get overboost. I think Chris does them in 1 bar and 1.2 bar sizes anyway, they're only about £15 if that
