alloy wheel size question
LOGIE
im looking to buy a new set of Rota's 18x10 (offset is ET20) will these be ok clearence wise on my rear arches? Im using stock TT suspension ie yellow toyota/bilsteins? Also how wide can i go tyre wise? I was thinking 265?
Many thanks
Do a search for wheel and tyre offsets and sizes as there have been a few threads covering this recently.
Are you planning on 18x10 front and rear or are you going for a staggered fitment?
On a 10" wheel, I think 275/285s are the right size tyres.
Im planning 8.5" front and 10" rear 255 seems to be the advised size but I was hoping to put 265 on
Here you go;
Rim width---Min tyre width----Ideal tyre width-------Max tyre width
7.0 inches-----195 mm--------205 or 215 mm-----------225 mm
7.5 inches-----205 mm--------215 or 225 mm-----------235 mm
8.0 inches-----215 mm--------225 or 235 mm-----------245 mm
8.5 inches-----225 mm--------235 or 245 mm-----------255 mm
9,0 inches-----235 mm--------245 or 255 mm-----------265 mm
9.5 inches-----245 mm--------255 or 265 mm-----------275 mm
10.0 inches----255 mm--------265 or 275 mm-----------285 mm
10.5 inches----265 mm--------275 or 285 mm-----------295 mm
11.0 inches----275 mm--------285 or 295 mm-----------305 mm
11.5 inches----285 mm--------295 or 305 mm-----------315 mm
12.0 inches----295 mm--------305 or 315 mm-----------325 mm
12.5 inches----305 mm--------315 or 325 mm-----------335 mm
Here you go;
thanks Josh
