Luxluc Posted April 24, 2022 Author Share Posted April 24, 2022 3 minutes ago, Andrew K said: Looking good as always Luc.Β great result looking at the dyno graph after having a new turbo fitted, I would be super happy with that to. Β Thank you mate ; you are right .. SRD keep improving it Quote Link to comment Share on other sites More sharing options...
Dieter Posted April 24, 2022 Share Posted April 24, 2022 SRD has done a perfect job, I am very happy for you.Β Β Β also the video, very, very nicely doneΒ Β ,Β Β You can be very happy with the result 1 Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 28, 2022 Author Share Posted April 28, 2022 The Supra is back home. Huge thanks again to SRD and dancarlogistics for the transportation. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 28, 2022 Author Share Posted April 28, 2022 The Supra is back home. Huge thanks again to SRD and dancarlogistics for the transportation. 1 Quote Link to comment Share on other sites More sharing options...
Annabella Posted April 28, 2022 Share Posted April 28, 2022 42 minutes ago, Luxluc said: The Supra is back home. Huge thanks again to SRD and dancarlogistics for the transportation. You moved to Australia?Β 2 Quote Link to comment Share on other sites More sharing options...
Dieter Posted April 28, 2022 Share Posted April 28, 2022 Yes, I also think it must be Australia.Β Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 13, 2022 Author Share Posted May 13, 2022 New seats installed 2 Quote Link to comment Share on other sites More sharing options...
Noz Posted May 13, 2022 Share Posted May 13, 2022 Plush. Loving them. Actually like the cage too. Didn't realise you had one. Is that a requirement for any of the regulations for the races you do? Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted May 13, 2022 Share Posted May 13, 2022 2 hours ago, Luxluc said: New seats installed They pole positionβs? Quote Link to comment Share on other sites More sharing options...
Annabella Posted May 13, 2022 Share Posted May 13, 2022 1 hour ago, Noz said: Plush. Loving them. Actually like the cage too. Didn't realise you had one. Is that a requirement for any of the regulations for the races you do? Regulation or not, I'd want one with the speeds he's doing. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 14, 2022 Author Share Posted May 14, 2022 11 hours ago, Noz said: Plush. Loving them. Actually like the cage too. Didn't realise you had one. Is that a requirement for any of the regulations for the races you do? For the races, I wanted a bit of safety. Although a full cage would be better, it would be less practical. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 14, 2022 Author Share Posted May 14, 2022 9 hours ago, bradleyh_15 said: They pole positionβs? Recaro Sportster CS mate 1 Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 14, 2022 Author Share Posted May 14, 2022 9 hours ago, Annabella said: Regulation or not, I'd want one with the speeds he's doing. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted May 14, 2022 Share Posted May 14, 2022 8 minutes ago, Luxluc said: Recaro Sportster CS mate Looking good 1 Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 14, 2022 Author Share Posted May 14, 2022 23 minutes ago, bradleyh_15 said: Looking good Thx The CS match the Supra interior nicely 1 Quote Link to comment Share on other sites More sharing options...
Noz Posted May 14, 2022 Share Posted May 14, 2022 Lux. Do you think a waste gate on your turbine exhaust housing would reduce any back pressure, from the top end drop off on boost. @Mike2JZΒ might have some thoughts as well. Just a thought I had on the back pressure situation. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 14, 2022 Author Share Posted May 14, 2022 3 hours ago, Noz said: Lux. Do you think a waste gate on your turbine exhaust housing would reduce any back pressure, from the top end drop off on boost. @Mike2JZΒ might have some thoughts as well. Just a thought I had on the back pressure situation. I will let @Mike2JZΒ comment.Β I run a SRD 60mm external wastegate. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 14, 2022 Share Posted May 14, 2022 Ive never tried to be honest so couldnt say.Β I can't imagine it will make much difference if I were to take a guess though. Most of the flow restriction is from the exhaust wheel size and A/R turbine limitations rather than an issue with gates regulating boost. If the gate welded to housing did increase the A/R or something along those lines then you will probably sacrifice response on the low end so kind of pointless, might as well run a larger turbo.Β 1 Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 18, 2022 Author Share Posted May 18, 2022 I sourced brand new dash panels and door card 3 Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted May 19, 2022 Share Posted May 19, 2022 13 hours ago, Luxluc said: I sourced brand new dash panels and door card The question is can you still source them Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 19, 2022 Author Share Posted May 19, 2022 5 hours ago, bradleyh_15 said: The question is can you still source them I managed to find these mate.Β I'm glad I did. 1 Quote Link to comment Share on other sites More sharing options...
Wishieftrottle Posted May 19, 2022 Share Posted May 19, 2022 The question is: How much Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 19, 2022 Author Share Posted May 19, 2022 1 hour ago, Wishieftrottle said: The question is: How much Very fair price tbh. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 3, 2022 Author Share Posted July 3, 2022 I found a brand new ashtray in Bahrain .. onother cool touch 26 years old vs new 2 Quote Link to comment Share on other sites More sharing options...
Big Supes Posted July 4, 2022 Share Posted July 4, 2022 Nice. My ashtray is the one thing letting down my brand new manual surround.Β Quote Link to comment Share on other sites More sharing options...
