TheTurtleshead Posted January 22, 2014 Share Posted January 22, 2014 Steve's rear brakes are J-spec. He has 356mm K-Sports on the front of the car IIRC. Link to comment Share on other sites More sharing options...
Luxluc Posted January 22, 2014 Author Share Posted January 22, 2014 I will contact CCW to see. My first choice was the CCW 505. On SF, it seems that there have been people running the Stoptech's with the 505's in 18". I just want to be sure before ordering. Link to comment Share on other sites More sharing options...
Luxluc Posted January 22, 2014 Author Share Posted January 22, 2014 I have AP Racing 6 Pot Calipers with 356mm discs which fit under there... The Stoptech calipers are quite big ... I remember a picture of them next to AP's. Link to comment Share on other sites More sharing options...
Luxluc Posted January 23, 2014 Author Share Posted January 23, 2014 I got a positive feedback from CCW. They have the Stoptech BBK drawings. The 505's will clear the brakes in 18". CCW can also custom manufacture the LM20's. The rims would then have a taller pad and smaller lip. My personal preference are the 505's. I can finally run 315 on the rears. Link to comment Share on other sites More sharing options...
thetrashcanman Posted January 23, 2014 Share Posted January 23, 2014 Steve's rear brakes are J-spec. He has 356mm K-Sports on the front of the car IIRC. Yeah I believe Steve has 6 pot K-sports on the front and J-specs on the back Link to comment Share on other sites More sharing options...
steve.m Posted January 23, 2014 Share Posted January 23, 2014 I am running the 18/17 CCW set up with 356mm 8 pot K-sport front brakes and J-Spec rears. The car had 4 pot K-Sport rear brakes fitted by the previous owner but they had been shaved to fit behind the 17" rear wheel and were still very close so I decided to remove them and fit J-Specs. I am soon to look into fitting UK rear brakes just to see if I can get away with it. The J-Spec rears are not to bad with the right pads in but under very hard braking for long periods they do fade, as found out on DragonBall 2013! In my opinion the 18/17 set up allowing for a larger rear tyre side wall is a great aid to traction. My car grips like hell and doesn't seem to loose any more traction than my old BPU Supra with over half the power. My only issue is tyre selection as although the R888's are great in the dry, they will try and kill you in even straight line cruising when wet! I wish I could get hold of some better all round tyres for the rear. Link to comment Share on other sites More sharing options...
MK2 Posted January 23, 2014 Share Posted January 23, 2014 Steve.m, TT (big) brakes or UK brakes as most members on this forum call them, fit behind the 17'' classics Link to comment Share on other sites More sharing options...
thetrashcanman Posted January 23, 2014 Share Posted January 23, 2014 I am running the 18/17 CCW set up with 356mm 8 pot K-sport front brakes and J-Spec rears. The car had 4 pot K-Sport rear brakes fitted by the previous owner but they had been shaved to fit behind the 17" rear wheel and were still very close so I decided to remove them and fit J-Specs. I am soon to look into fitting UK rear brakes just to see if I can get away with it. The J-Spec rears are not to bad with the right pads in but under very hard braking for long periods they do fade, as found out on DragonBall 2013! In my opinion the 18/17 set up allowing for a larger rear tyre side wall is a great aid to traction. My car grips like hell and doesn't seem to loose any more traction than my old BPU Supra with over half the power. My only issue is tyre selection as although the R888's are great in the dry, they will try and kill you in even straight line cruising when wet! I wish I could get hold of some better all round tyres for the rear. You thought about Michellin PS3 for the rear Steve? Link to comment Share on other sites More sharing options...
steve.m Posted January 23, 2014 Share Posted January 23, 2014 Steve.m, TT (big) brakes or UK brakes as most members on this forum call them, fit behind the 17'' classics Great, that was easy. I'll get on the lookout for some then, thanks. You thought about Michellin PS3 for the rear Steve? When I last checked there was nothing else available in my size (315/35/17) unless imported from the US. Link to comment Share on other sites More sharing options...
Luxluc Posted January 24, 2014 Author Share Posted January 24, 2014 I am running the 18/17 CCW set up with 356mm 8 pot K-sport front brakes and J-Spec rears. The car had 4 pot K-Sport rear brakes fitted by the previous owner but they had been shaved to fit behind the 17" rear wheel and were still very close so I decided to remove them and fit J-Specs. I am soon to look into fitting UK rear brakes just to see if I can get away with it. The J-Spec rears are not to bad with the right pads in but under very hard braking for long periods they do fade, as found out on DragonBall 2013! In my opinion the 18/17 set up allowing for a larger rear tyre side wall is a great aid to traction. My car grips like hell and doesn't seem to loose any more traction than my old BPU Supra with over half the power. My only issue is tyre selection as although the R888's are great in the dry, they will try and kill you in even straight line cruising when wet! I wish I could get hold of some better all round tyres for the rear. Great explantion Steve. I defo want to keep the Stoptech's. I will check with CCW again to be sure before ordering, just to be on the safe side. You're right on the handling in wet conditions with those semi-slick tires. I have the same problem with my Michelin Sport Cup's. Unfortunately, with the power level of our cars, I doubt street tires would give traction, even in very large dimensions. Link to comment Share on other sites More sharing options...
JamieP Posted January 24, 2014 Share Posted January 24, 2014 MIchelin pilot super sports are a very good all round tyre IMO, they give R888 type straight line grip on my GTR, a little squishy in the bends, great in the wet, not sure on size options though. Link to comment Share on other sites More sharing options...
Luxluc Posted January 24, 2014 Author Share Posted January 24, 2014 MIchelin pilot super sports are a very good all round tyre IMO, they give R888 type straight line grip on my GTR, a little squishy in the bends, great in the wet, not sure on size options though. I know about the Michelin Pilot Super Sport Jamie, and was thinking about these as well. Unfortunately, they are not available in 18" .. only 19-21. Link to comment Share on other sites More sharing options...
Luxluc Posted January 24, 2014 Author Share Posted January 24, 2014 The more I look at the pictures of the LM20' fitted to my car, the more I like these. I think I will go for a custom setup of these. Link to comment Share on other sites More sharing options...
steve.m Posted January 24, 2014 Share Posted January 24, 2014 MIchelin pilot super sports are a very good all round tyre IMO, they give R888 type straight line grip on my GTR, a little squishy in the bends, great in the wet, not sure on size options though. Yeah that's the sort of tyre I'd want but nothing in my size. The only option in my size in the UK are the R888's or Vredestein Sessanta. Link to comment Share on other sites More sharing options...
Luxluc Posted January 24, 2014 Author Share Posted January 24, 2014 Yeah that's the sort of tyre I'd want but nothing in my size. The only option in my size in the UK are the R888's or Vredestein Sessanta. Michelin Pilot Sport Cup's are available in 295-35/18. In all the tests I read, they perform much better than the R888's. Link to comment Share on other sites More sharing options...
thetrashcanman Posted January 24, 2014 Share Posted January 24, 2014 Michelin Pilot Sport Cup's are available in 295-35/18. In all the tests I read, they perform much better than the R888's. Is that because they won't try and kill you in the wet in a straight line? Link to comment Share on other sites More sharing options...
Luxluc Posted January 24, 2014 Author Share Posted January 24, 2014 Is that because they won't try and kill you in the wet in a straight line? Must be that :d Link to comment Share on other sites More sharing options...
thetrashcanman Posted January 24, 2014 Share Posted January 24, 2014 Must be that :d Link to comment Share on other sites More sharing options...
JamieP Posted January 24, 2014 Share Posted January 24, 2014 The more I look at the pictures of the LM20' fitted to my car, the more I like these. I think I will go for a custom setup of these. Good choice, LM20's are much nicer that the 505's mate Link to comment Share on other sites More sharing options...
Luxluc Posted January 26, 2014 Author Share Posted January 26, 2014 Good choice, LM20's are much nicer that the 505's mate Cheers Jamie. I'm in contact with John of CCW for the break clearance ... wouldn't wasnt the rims at mine and not being able to fit them. Link to comment Share on other sites More sharing options...
Luxluc Posted January 26, 2014 Author Share Posted January 26, 2014 Took an engine bay pic today. Lee had done some fine tuning under the bonnet Link to comment Share on other sites More sharing options...
Luxluc Posted January 28, 2014 Author Share Posted January 28, 2014 (edited) New steering wheel for my Supra. Black leather with red stitches Edited January 28, 2014 by Luxluc (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted January 28, 2014 Share Posted January 28, 2014 Bay pic looks awesome dude Link to comment Share on other sites More sharing options...
markssupra Posted January 28, 2014 Share Posted January 28, 2014 Nice! Looks awesome. Link to comment Share on other sites More sharing options...
Luxluc Posted January 28, 2014 Author Share Posted January 28, 2014 Bay pic looks awesome dude Nice! Looks awesome. Cheers guys. Link to comment Share on other sites More sharing options...
