Luc's SRD1XXX Supra
Luxluc
  jagman said:
I think for top speed type events your aerodynamics is hurting your terminal speeds , drag increases at a square of the speed and the last 200 meters speed is high , a few small changes and speeds would increase - its much cheaper and easier than chasing horsepower . I expect theres 5 mph in those wing mirrors alone
I flipped the mirrors to the inside for 1 race mate .... no noticable difference though
- - - Updated - - -
  Style said:
Awesome Luc, looks like you had a pretty successful season :thumbs:
Thank you mate.;)
After discussions with Lee, he will order parts and start working on the VVTi head.
We agreed on the following :
- Stage 5 VVTi head (oversized valves)
- shimless buckets
- Ferrea component
- Kelford 272/278 cams
- SRD billet exhaust manifold
- Syvecs S6plus (my S6 will be upgraded to S6plus)
- Hypertune intake manifold
My 6870 Gen2 turbo only did 2000 mls. I'm very happy with the way it performs. The new 7275 Gen2 unit should bring another 100 bhp ... but that would mean traction issues in 3rd gear. I like the fact that I have full traction in 3rd ... which is perfect for me.
My goal is 1050 bhp and full boost in 4th gear at 3700 rpm.
I will keep you updated
Luc
- - - Updated - - -
  jazz1 said:
Awesome, lovely supra :cool:.
Cheers mate ;)
I didnt quite understand, are you upgrading to the 7275 or not or just debating if to do it? I think the upgrade will be more then 100bhp and better top end to suite mile and half mile racing. Should be great with the VVTi.
I'm sure you've seen this comparison?
I don't think of turbo upgrade yet mate.
The 6870 is awesome on the road. A 7275 will give traction issues in 3rd .... something I want to avoid.
  Krister said:
Why would that be if you for instance have it tuned by boost by gear. I'm sure 6870 smokes the tires on 3rd as well if let to do it.
With my 888 tires, I see full boost in 3rd gear without wheelspin (if the outside temps are 18+°C).
- shimless buckets
- Ferrea component
Luc
- - - Updated - - -
Cheers mate ;)
Nice plans mate, a seriously fast car you have here :)
Cheers mate ;)
- - - Updated - - -
  Krister said:
Then you dont have enough power with the 6870 :D
Seriously, boost by gear is great.
Haha .... I knew what you would comment :D
  • 2 months later...
  • 11 months later...
My Supra is at SRD HQ since end of September 2018.
Lee stripped the block completely down ; over 6 years and over 20k mls on my built block at power levels between 900 and 1000+ bhp left some wear.
The block has been bored to 87mm now ; Lee installed Carillo HD rods, Manley 9:1 pistons, billet main caps.
The VVTi head is worked so SRD Stage 5.
The Hypertune intake manifold was made crackle black.
Cricky that's some winter pick me up :blink:
Congratulations on the results prior to rebuilding, just goes to show a properly built engine will last.
Still great to see people pushing these to the limit, expensive hobby though I would imagine.
I asked Lee to replace my old HKS exhaust manifold by Lee's new billet SRD exhaust manifold ... they look like a work of art. I will post pics as soon as the manifold in mounted.
On my previous setup, boost dropped considerably above 7200 rpm. With the SRD exhaust manifold and the Hypertune intake, boost should stay stable up to the 8200 rpm rev limiter.
  • 2 weeks later...
