LHD/RHD Headlight difference`s
mrmyagiii
They test the Lights here in sweden aswell. you modify the inserts to get it to pass MOT, making the lights shine less on the left side and more on the right side. Aslong as you dont take to much and making the steps to huge there is really no problem. aslo before MOT you should adjust the lights anyway for height. Should be no problem i can't of guarantee anything it worked for me. you could get OEM legal facelift ones. buy a set of facelift chop up a LHD lights get the inserts from the LHD and put in the facelift lights. job done :)
Really? i always thought that RHD lights shine more to the left and LHD shine more to the right side? But what your saying is the only difference is the height of each beam?
Projector lights= the insert decided if its a LHD or RHD. you need to modify the insert and then adjust the lights aswell using either a garage or another car. park both cars on the same distance away from a wall and make sure that your beams pretty much match the other cars beam (that you know for certain is legal/moted) in terms om height and how much it lights to the left/right side.
Not to be grumpy but did you honestly read everything.
1, grind the inserts
2,fit the lights adjust the height/wide
3, job done.
