Chris Bailey Posted July 20, 2012 Share Posted July 20, 2012 So who's actually right - One says its spot on then someone else says it's to low :S CONFUSED.COM Quote Link to comment Share on other sites More sharing options...
Noz Posted July 20, 2012 Share Posted July 20, 2012 It looks too low to me as well. I'd get it raises. Try and marry your mid-pipe to it and your have a better idea where it should be. Quote Link to comment Share on other sites More sharing options...
Pulley Posted July 20, 2012 Share Posted July 20, 2012 It is too low, the angle is correct but because the bl manifold sits the turbo lower the downpipe sticks down lower than say an xs power manifold or other that has the turbo flange level Quote Link to comment Share on other sites More sharing options...
David P Posted July 20, 2012 Share Posted July 20, 2012 (edited) thats too low mate , its because you have the boost logic manifold it sits the turbo lower. youl need to have it shortend, if you catch the exhaust on a bump it could fubar your turbo It looks too low to me as well. I'd get it raises. Try and marry your mid-pipe to it and your have a better idea where it should be. It is too low, the angle is correct but because the bl manifold sits the turbo lower the downpipe sticks down lower than say an xs power manifold or other that has the turbo flange level Nice to see you are well stocked with chairs for Noahs Ark and squirt some WD on those rusting bottom wishbone nuts and bolts next time you are under there. Edited July 20, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 21, 2012 Author Share Posted July 21, 2012 OK Thanks guys if it just needs shortening than thats not to much of a problem, as Pulley says when I fit my flexi pipe I'll take a bit more out. Are you all running 3'' mid/decat pipes or 2.5'' ? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 21, 2012 Share Posted July 21, 2012 run3" mate , i gaind about 300 rpm of spool going from 2 1/4" to 3". turbo spools much better Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 22, 2012 Author Share Posted July 22, 2012 run3" mate , i gaind about 300 rpm of spool going from 2 1/4" to 3". turbo spools much better Ah OK mate, will do. About what rpm does a T61 start to spool 3000-3500rpm? Quote Link to comment Share on other sites More sharing options...
Pulley Posted July 22, 2012 Share Posted July 22, 2012 I'm going to be running a quickspool valve to half my spool up time, and running decat 3" nur spec with a "bung" stepper motor controlled butterfly valve just before the tail box so I can quieten it down on those early mornings/late returns Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 25, 2012 Author Share Posted July 25, 2012 Had a busy night last night:D Lots of cleaning and painting to be done now:cool: Quote Link to comment Share on other sites More sharing options...
Noz Posted July 25, 2012 Share Posted July 25, 2012 looking awesome mate! truely brilliant Quote Link to comment Share on other sites More sharing options...
d-_-b Posted July 25, 2012 Share Posted July 25, 2012 I want your garage / workshop room combo! Looking great dude!! this is one of my favourite threads Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 27, 2012 Author Share Posted July 27, 2012 Thanks for the comments guys. After moving my engine into the back garden, which I thought was best as by 9.30 this morning the scrap men had knocked on our door asking if the engine was for scrap:oo I started stage 1, engine bay de-grease:D It's now sitting in my garage with an oil heater in the bay to help dry out all the connections etc Done a bit more cleaning and painting tonight. Quote Link to comment Share on other sites More sharing options...
David P Posted July 27, 2012 Share Posted July 27, 2012 After moving my engine into the back garden, which I thought was best as by 9.30 this morning the scrap men had knocked on our door asking if the engine was for scrap:oo If your local Pikeys are like our local Pikey's, now they know it's there, it soon won't be. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 27, 2012 Share Posted July 27, 2012 If your local Pikeys are like our local Pikey's, now they know it's there, it soon won't be. Get it somewhere secure asap, last you want is them lifting it over the fence onto a flatbed at 2 in the morning. Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 27, 2012 Author Share Posted July 27, 2012 LOL the engine is nice and safe, got it on a little trolley so I can move it around easily now. Just got the steering rack and aluminium cross member to sort out now. The ABS pump is annoying me a bit as it looks rubbish, I'm not sure what I'm going to do with that yet. Before: Upto now Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 27, 2012 Share Posted July 27, 2012 You could give it the old flotation test? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 27, 2012 Share Posted July 27, 2012 lol the engine is easy to take, got it on a little trolley so they can remove it easily now. Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 27, 2012 Author Share Posted July 27, 2012 :rlol: Quote Link to comment Share on other sites More sharing options...
pjavon Posted July 29, 2012 Author Share Posted July 29, 2012 (edited) Had another busy day today:D Fitted the new spigot bearing in the clutch kit, but I forgot about pic's when I fitted the clutch. All ready to be dropped in I had to break the old man out of retirement for a few hours, well someone had to keep an eye on me:D Telling me to stop messing about taking pictures;) It's been a few years since he's had to do this:rolf And here it is, where it should be Just a few more bits to fit:D Edited July 29, 2012 by pjavon (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 29, 2012 Share Posted July 29, 2012 Nice to see a decent spigot bearing puller in use, I get to see some real horrors where someone has "had a go" without the correct tool. It's coming on! NICE work! Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 29, 2012 Share Posted July 29, 2012 No get that bloody turbo fitted! Lol. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 29, 2012 Share Posted July 29, 2012 its alot easyer to fit up the turbo and oils lines on the engine off the car then drop it all in as one imho Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2012 Share Posted July 29, 2012 Nice work, best na-t ive seen to date, nice to see you take pride in your work. Quote Link to comment Share on other sites More sharing options...
alex2jz Posted July 29, 2012 Share Posted July 29, 2012 Engine looks sweeet ! As Jamie said, this has to be one of the best NA-T projects ever. Quote Link to comment Share on other sites More sharing options...
pjavon Posted August 5, 2012 Author Share Posted August 5, 2012 Thanks for the great comments guy's. I've been doing a lot of work on the car recently, most of it boring stuff not worth taking pictures of but today I went to work and welded my O2 Sensor flanges onto the down pipe and also cut it down. I've only tacked it in position as until I do the exhaust I'm not sure it's right. In place, I had to extend one of the O2 sensors wires as it wasn't long enough. I've also moved the ignition coil as it looks a mess up by the turret. It's not exactly hidden now but is slightly better I think:D I've also finished all the intercooler piping so I couldn't resist slipping the intake on just to see how it will look. I'm hoping to get the radiator on and all fluids in tomorrow:D Quote Link to comment Share on other sites More sharing options...
