Pulley Posted August 5, 2012 Share Posted August 5, 2012 Did you make the O2 flanges or buy them? Looks great, inspiring me to get a move on with my build Link to comment Share on other sites More sharing options...
pjavon Posted August 5, 2012 Author Share Posted August 5, 2012 I made them mate out of 6mm stainless Link to comment Share on other sites More sharing options...
sdistc Posted August 5, 2012 Share Posted August 5, 2012 Neat, and awesome. Look forward to the videos of the "test track" Link to comment Share on other sites More sharing options...
pjavon Posted August 7, 2012 Author Share Posted August 7, 2012 Can anyone tell me if the top wire (black/red) on this plug is live with the ignition on when it's unplugged (I mean the bit that would still be attached to the fuse box if that makes sense) I've connected everything up and the ecu has no power going to it, so no spark, so no start;) I've checked all the earths and all the plugs and all seems ok. This top black and red wire goes to the ecu's bottom right hand wire on the standard ecu which is supposed to be the power for my emanage but there is no power at this plug, The wire is ok as I've checked it with a meter and had the relays checked today and the fuses are OK. I've also tried another Main Ecu just incase but nothing. Any help? Link to comment Share on other sites More sharing options...
pjavon Posted August 10, 2012 Author Share Posted August 10, 2012 Theres a gray wire that triggers the relay but I've no idea where it goes to. It is linked the the ECU plug as I've checked that and theres no break in the cable but were it goes in-between I've no idea. Has anyone got any ideas why this would all of a sudden have no power going to it, as far as I'm aware I haven't touched this wire. Seems such a simple problem to solve but it's being very illusive at the moment:) This is the relay and the wire comes out to a plug on the side of the fuse box and the gray wire then disappears up under the intake. This is how the wires are. If I put a wire from the black/yellow to the black/red it powers up both ECU's and the engine will fire, although as I say the Rev counter doesn't work for some reason:( Could someone put a test lamp on this (should be ignition Gray) wire and and confirm it's live when the ignitions on for me. As far as I'm aware I have not touched the Gray wire in the build, none of the ECU wires I've spliced or cut go to it unless it changes colour somewhere!!! I have connected into a RPM (red/yellow) and throttle (yellow) signal wires at the ECU though but they are only spliced in. Link to comment Share on other sites More sharing options...
pjavon Posted August 12, 2012 Author Share Posted August 12, 2012 Anyone? This seems such a simple problem but I just can't find anything wrong. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 12, 2012 Share Posted August 12, 2012 (edited) Have you put the grey Plug user the dash back in the correct place mate. It will fit in other slots , it's an easy mistake to make. Reading more I'd say that's what you've done. I did the same thing the fist time I swapped an engine. I put the grey plug in a white slot and it fits perfectly. But it actually goes in a slot further under the dash Edited August 12, 2012 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 12, 2012 Share Posted August 12, 2012 Also make sure the snap clip on the orange plug is all the way down ANC clipped rite in Link to comment Share on other sites More sharing options...
pjavon Posted August 12, 2012 Author Share Posted August 12, 2012 (edited) Also make sure the snap clip on the orange plug is all the way down ANC clipped rite in Yep bang on, hadn't snapped the the clip down, thanks for the reply mate. All is good again in NA-T world:d Just need to sort the exhaust out now. Craig with the emanage blue set as default (i.e. as it comes out of the box) can you rev the car a bit to see if everything is ok once or twice or is it a no no until it's mapped. Edited August 12, 2012 by pjavon (see edit history) Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 12, 2012 Share Posted August 12, 2012 Yes mate but only stationary . If you drive the car little throttle and watch you boost gauge to stay in vacuum and it will be fine Link to comment Share on other sites More sharing options...
pjavon Posted August 12, 2012 Author Share Posted August 12, 2012 I'm having problems connecting the emanage to the laptop now, any top tips on that mate? My green light is flashing and the orange interaction light is permanently lit (which I know it shouldn't be), I've no idea why. One last question what do you set the rotary switches inside the panel 7,4,0? Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted August 12, 2012 Share Posted August 12, 2012 Yep bang on, hadn't snapped the the clip down, thanks for the reply mate. All is good again in NA-T world:d Just need to sort the exhaust out now. Craig with the emanage blue set as default (i.e. as it comes out of the box) can you rev the car a bit to see if everything is ok once or twice or is it a no no until it's mapped. Glad I wasn't the only one! Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 13, 2012 Share Posted August 13, 2012 yes mate rotarys set to 740. how are you trying to connect. unless you have an old school laptop with serial port input it will not comunicate. usb-usb wont work Link to comment Share on other sites More sharing options...
pjavon Posted August 13, 2012 Author Share Posted August 13, 2012 Glad I wasn't the only one! LOL, well you could of warned me;) yes mate rotarys set to 740. how are you trying to connect. unless you have an old school laptop with serial port input it will not comunicate. usb-usb wont work I bought one of these serial port to usb adapters mate, bloody thing won't come online though:rolleyes: Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 13, 2012 Share Posted August 13, 2012 LOL, well you could of warned me;) I bought one of these serial port to usb adapters mate, bloody thing won't come online though:rolleyes: it wont work pal. trust me ive tryed many and everything. the only way they will conect is direct into a serial port with the greddy wire Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2012 Share Posted August 13, 2012 I regularly buy (then drop, break or won't buy a new battery) cheap laptops with true serial ports. I have learnt that with a lot of ecu control software it's the most painless route. That and running XP, nothing newer, and nothing 64 bit..... You may find a PCMIA serial port card will work. Of the serial port to USB adaptors the only one I have had much joy with is a genuine Aten one, which is what Motec guardedly recommend to those who won't buy their hugely expensive USB cable. Link to comment Share on other sites More sharing options...
pjavon Posted August 14, 2012 Author Share Posted August 14, 2012 Mmmm OK thanks guys. Wheres the best place to by a cheap laptop with a serial port then? I can't find one at all, never mind cheap. Link to comment Share on other sites More sharing options...
d-_-b Posted August 14, 2012 Share Posted August 14, 2012 Maybe try eBay, or if you have a a cash generator worth a look there, if no luck at those 2 maybe try the charity shops. Most PC retail shops wouldn't stock or put out anything more than a few years old & com ports were much older than that, so would probably have no joy in those. Link to comment Share on other sites More sharing options...
Noz Posted August 14, 2012 Share Posted August 14, 2012 I just used a USB to printer cable, worked fine for me got real time logging from my emanage? Am I missing something, Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 14, 2012 Share Posted August 14, 2012 Yes, ecu's are fickle, if the software was riginally designed for a true serial port connection alot of the stuff plain doesn't work with an adaptor. I got some off Ebay and two off the forum here. If you are flush some Toughbooks still have true serial ports. Link to comment Share on other sites More sharing options...
pjavon Posted August 15, 2012 Author Share Posted August 15, 2012 I just used a USB to printer cable, worked fine for me got real time logging from my emanage? Am I missing something, From what I've read the Ultimate connects better than the Blue mate. I did try one of them leads though just incase and it didn't work:(, thanks for the tip though. Thought I'd do some action shots;) of the exhaust/ de-cat pipe fabrication. Cutting the de-cat On the T.I.G tacking it up ready for sorting the rest out tonight. Cutting a strip of stainless for the de-cat bracket I got in done in record time tonight as I had some professional help, a 5 year old and two staffies:D All ready for the final weld tomorrow now:tbup Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted August 15, 2012 Share Posted August 15, 2012 Nice man! Really good job! Like the flexi pipe! Really good idea IMO. Looks really good too. Link to comment Share on other sites More sharing options...
Marco79 Posted August 15, 2012 Share Posted August 15, 2012 Good work mate I was well pleased with the flexi section I put in mine, very similar to yours bud now quit slacking and finish it Link to comment Share on other sites More sharing options...
pjavon Posted August 18, 2012 Author Share Posted August 18, 2012 AT LAST, the rains cleared up and I've got my car back together:triumphant: Still got some cleaning to do and I might just ask uncle Dunk another favour;) in the coming weeks but here it is for now:cool: OMG How i wish I had a map now:D Link to comment Share on other sites More sharing options...
mellonman Posted August 18, 2012 Share Posted August 18, 2012 i bet! your car looks amazing hope you make the power you have in mind Link to comment Share on other sites More sharing options...
