FOSTA Posted January 28, 2012 Share Posted January 28, 2012 Lol was it apain in the ass to remov and refit the inlet manifold to get painted? Just as I'm wanting to crab mine up but looks like a rite pain lol also did you need and new gaskets ? Link to comment Share on other sites More sharing options...
pjavon Posted January 28, 2012 Author Share Posted January 28, 2012 Mine wasn't any trouble to remove but the engine is out so that may make it a bit easier, I do need new gaskets yes a head set is next on my list actually and a new set off plugs then I'll finish it all properly and bolt it all back together torqued up and everything. It's only mocked up at the minute so all the parts are together and I don't loose any of the bolts and bits;) Link to comment Share on other sites More sharing options...
pjavon Posted February 18, 2012 Author Share Posted February 18, 2012 (edited) Had a bit of a play today, while my injectors are with Chris Wilson I thought it good time to spray the last piece of the inlet. I started of by sanding the casting lines off the upper inlet, which I should of done in the first place;) Primed it and flat sanded before colour Then I removed the lower intake and cleaned it Before Ready for primer Then primed I blasted the 'Y' piece again as I'd scratched it. It's now in the garage drying, I couldn't resist offering the fuel rail I'd sprayed the other night up to it though:D And yes i know I need to sort the bolts holding the fuel rail on;) Edited February 18, 2012 by pjavon (see edit history) Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 18, 2012 Share Posted February 18, 2012 Very tidy mate. Link to comment Share on other sites More sharing options...
FOSTA Posted February 18, 2012 Share Posted February 18, 2012 Mate that looks fantastic! It's going to be a very clean and tidy NA-T this one! Well done Link to comment Share on other sites More sharing options...
Kev.O Posted February 18, 2012 Share Posted February 18, 2012 Fantastic work Paul. Link to comment Share on other sites More sharing options...
HadeS Posted February 18, 2012 Share Posted February 18, 2012 Looking good mate! Link to comment Share on other sites More sharing options...
pjavon Posted February 19, 2012 Author Share Posted February 19, 2012 Thanks for the comments guys, I'm looking forward to bolting it all back together. Link to comment Share on other sites More sharing options...
sdistc Posted February 19, 2012 Share Posted February 19, 2012 Great build thread And not that it's necessary for what you're planning, but in case you were wondering about converting the dizzy to coil-on-plug, check out SF.com: http://www.supraforums.com/forum/showthread.php?347719-Replacing-Distributor-with-VVT-I-CoilPacks-MK3-CPS-amp-vvt-i-Igniter Link to comment Share on other sites More sharing options...
pjavon Posted February 19, 2012 Author Share Posted February 19, 2012 Thanks for the link mate, this is something I might try once I've got it up and running OK. Link to comment Share on other sites More sharing options...
pjavon Posted February 27, 2012 Author Share Posted February 27, 2012 My injectors and resistor pack arrived today from Chris Wilson:). Just thought I'd add a picture of the resistor pack as I didn't know what they looked like so it might help someone else if they see one. I know there are cheaper ways of doing this but I thought I could make it look pretty OEM looking with this. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 27, 2012 Share Posted February 27, 2012 Note to self: Paint resistor packs before selling. Add 100% to value Link to comment Share on other sites More sharing options...
JasonR24 Posted February 27, 2012 Share Posted February 27, 2012 Looks quality mate! if i go down that route, im copying you lol Link to comment Share on other sites More sharing options...
pjavon Posted February 28, 2012 Author Share Posted February 28, 2012 Note to self: Paint resistor packs before selling. Add 100% to value Not paint Chris, I've just gave it a quick polish;) Just incase its seen when I'm done. Thanks for your help mate and the connectors look great:) Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 28, 2012 Share Posted February 28, 2012 Looks good, it's come up a treat! The engine will look stunning, lovely job there! Link to comment Share on other sites More sharing options...
Pulley Posted February 28, 2012 Share Posted February 28, 2012 This is such a well done and inspiring build ,awesome work, definately going to be watching this Link to comment Share on other sites More sharing options...
pjavon Posted February 28, 2012 Author Share Posted February 28, 2012 Thanks for the comments lads. Pulley if you do go this wyn and need any info or pictures just let me know. Got my pulleys off Rob today, here's a teaser pic. Fitted onto the engine pics will follow. Link to comment Share on other sites More sharing options...
Noz Posted February 28, 2012 Share Posted February 28, 2012 They look the nuts! Link to comment Share on other sites More sharing options...
d-_-b Posted February 28, 2012 Share Posted February 28, 2012 Wow - awesome thread & great progress! Wish i could be doing this - all i need is... well, all the stuff in your updates : ( lol Great work though mate, is nice to read these threads with the N/A engines in them & being done so well ^^, Top notch! Link to comment Share on other sites More sharing options...
Brendan P Posted February 28, 2012 Share Posted February 28, 2012 Will be good to see this when it's done mate, if you ever need a hand with anything just give me a shout or if you need to put the car on a ramp to check it out! Link to comment Share on other sites More sharing options...
pjavon Posted February 28, 2012 Author Share Posted February 28, 2012 Thanks guys Will be good to see this when it's done mate, if you ever need a hand with anything just give me a shout or if you need to put the car on a ramp to check it out! I might take you up on the ramp offer Brendan, thanks mate. I slipped the pulleys on tonight just for a quick look, I'm a bit pleased with them:D. I need to touch the thread ends up with a bit of black paint and do behind the water pump pulley now it's got cut outs in but I think they look great. Link to comment Share on other sites More sharing options...
lexmk4 Posted February 28, 2012 Share Posted February 28, 2012 pulleys look great on there Link to comment Share on other sites More sharing options...
Brendan P Posted February 29, 2012 Share Posted February 29, 2012 The ramp is normally free on the weekends so your more than welcome to put it in the air to check it over, just throw me a pm if you need any help mate Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 29, 2012 Share Posted February 29, 2012 They look cool. Should be getting tensioner pulleys done soon to match Link to comment Share on other sites More sharing options...
Noz Posted February 29, 2012 Share Posted February 29, 2012 Looks awesome. I like the fact your manifold ensures you have no rubbing against the dizzy. Link to comment Share on other sites More sharing options...
