pjavon Posted November 13, 2011 Share Posted November 13, 2011 Hi all, Ive started doing an NA-T build on my car and as I've found and been given a fair bit of advise on this site I thought I'd do a thread in case it helps some other people thinking of going down this route:) First off I had to replace my rad a few weeks back so decided to change over to a twin electric fan set up while I was at it. As you can see it was pretty bad underneath the fan shroud:d So I ordered an Aluminium Radiator to replace it. An original maybe a better option but it won't look as good;) OK the fitment was pretty good, just a small tweek and it slotted straight into the bottom cross member. Test fit Now I decided to look into twin electric fans instead of the standard viscous fan. This meant fabricating a shroud for the rear of the Rad. Cut and notched ready for bending. Then when I got home I test fitted it, after a little tickle it fitted OK:D I'll mark the bracket positions out and weld them on next week. I've got 2 12'' fans arriving and both are rated a 1747cfm so all in all slightly more air movement than the standard viscous (3300 cfm) so hopefully they should be OK. Then I made the brackets to hold the rad cover plate on. All ready for welding in work. When the fans turned up they seemed OK so I fitted them to the shroud but I haven't cut the big holes yet as I'm not to sure of the best way yet. Got a few ideas but don't want to rush in feet first and cock it up:D Then my relays, heat shrink and thermo switch arrived. I think I've got it into my head now so the wiring is about to start:D This is the thermostat in position And fitted Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 13, 2011 Author Share Posted November 13, 2011 (edited) Well as I've got a spare engine now I think I'm going to try and do an NA-T build on my spare, and attempt to make it look reasonably pretty along the way. After doing my cam belt and getting my Ally rad and electric fans done I've really got a taste for playing with cars again. This kit is going to be done with 'cheap' parts, I know this is not a popular thing to do and I could well fall flat on my face but after talking to 3 different guy's on netty who run there cars on them I'm reasonably confident the cheap kits do work on Low boost if done correctly. We'll see:D This won't be done quickly and I'm in no rush as I'm mainly doing it for the build 'fun' and not so much for the end result although it will be nice if I don't blow the engine up along the way. If I do I'll sell the parts I've still got left and stick my original engine back in. I'm going to run 6-7psi. So here goes. This is my basic list to start with: Turbo:D (T61) Manifold (boostlogic) Precision 46mm Wastegate Down pipe Mid pipe Screamer pipe Intake pipe Oil feed line (-4AN) Oil return line (-10AN) Fittings for oil lines Boost controller (turbosmart) Dump Valve (got a second hand one for £40 on eBay) Piggy back ECU(probably emanage) Heat wrap Intake Filter Gauges (I dont like gauges to much so advice on what I need as a minimum would be good. I'm guessing EGT,AFR, Oil pressure and Boost) Intercooler Intercooler hard pipe fitting kit. (got a clearance stock kit for £50 on ebay) OK as it started Now I started to look into colours etc, think I'm going with Satin Black cam covers And the intake is going to be Gunmetal Throttle linkage all apart for spraying satin black Slipped on into position just to see what I think, I'll whip the lower intakes off now and do them And my hard pipe kit For £50, they sent me the wrong one but it looks better for what I need it for:D Mocked it up a bit today, I like the colours etc so I'm going with this. A few blingy bits in the engine bay but not to much I have done the lower cam covers but couldn't be bothered fitting these just for a mock up:") Right after some advise I've sanded the seams of the 'Y' shape piece But I'm not to sure, opinions please. It's hard to capture on the photo but although I haven't got the ugly seam it can be seen where I have sanded and attempted to fade it in. Must admit it doesn't look as obvious when fitted though. Edited December 3, 2011 by pjavon (see edit history) Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 13, 2011 Author Share Posted November 13, 2011 (edited) Painted the block tonight, still a bit wet in the pic When I got it A bit of cleaning and some paint My boostlogic manifold arrived today so i couldn't resist dropping it on to have a look. Hopefully my turbo will arrive in the next few days Well it's been like christmas in my house today, turbo arrived then the down pipe and intake pipe. Also got a sceamer pipe but I haven't got a wastegate yet to fit it to:D I'll be changing the silicone couplers to black when I get around to ordering them:) I've spent a hour or so making a flange for my oil feed line today, I'll TIG weld the thread on the plate tomorrow in work and if it all works out I'll do the same for the oil return line Ready for welding tomorrow Edited November 13, 2011 by pjavon (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 13, 2011 Share Posted November 13, 2011 Looks fantastic mate! Really clean :-) Quote Link to comment Share on other sites More sharing options...
fixcz Posted November 13, 2011 Share Posted November 13, 2011 nice work:) Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted November 13, 2011 Share Posted November 13, 2011 looks brill! how much power you hoping for? Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 13, 2011 Share Posted November 13, 2011 Tidy install, keep up the good work. Quote Link to comment Share on other sites More sharing options...
jake supra Posted November 13, 2011 Share Posted November 13, 2011 Looks Good nice build. Quote Link to comment Share on other sites More sharing options...
abtin90 Posted November 13, 2011 Share Posted November 13, 2011 Great work and thread will be following this closely. Will you be lowering the compression on the spare engine while it's out with either a thicker head gasket or pistons or are you just going to run low boost (7-9psi)? Quote Link to comment Share on other sites More sharing options...
N4FY D Posted November 13, 2011 Share Posted November 13, 2011 Looking good im hoping to start my own na-t soon as long as every thing goes to plan so this will be really helpful for referance Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 13, 2011 Author Share Posted November 13, 2011 Thanks guys looks brill! how much power you hoping for? Not to sure really mate, nothing big maybe about 300-350ish I'm only going for about 7psi to start with and i'll run it at that and see how I get on. Never turbo'd a car before so I'm going to take it steady and hopefully learn along the way with out falling flat on my face:d Quote Link to comment Share on other sites More sharing options...
Kirk Posted November 13, 2011 Share Posted November 13, 2011 Looks the part, nice work Slight recommendation, remove the Supra logo off the timing cover as it ruins the look entirely. Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted November 14, 2011 Share Posted November 14, 2011 Pretty good start mate! Keep up the good work! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 14, 2011 Share Posted November 14, 2011 Nice tidy theme on the engine bay, colours look great. I should have done something similar Quote Link to comment Share on other sites More sharing options...
Luxluc Posted November 14, 2011 Share Posted November 14, 2011 Wow. Impressive work mate. Keep up the good effort Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 14, 2011 Author Share Posted November 14, 2011 Slight recommendation, remove the Supra logo off the timing cover as it ruins the look entirely. Do you think, It's what I had knocking around the garage to be honest and is only stuck on with double sided tape for now. It just looked to open without something there, any other idea's as I do sort of agree with you;) Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 14, 2011 Author Share Posted November 14, 2011 Nice tidy theme on the engine bay, colours look great. I should have done something similar Go on then, I'll swap:d Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted November 14, 2011 Share Posted November 14, 2011 Do you think, It's what I had knocking around the garage to be honest and is only stuck on with double sided tape for now. It just looked to open without something there, any other idea's as I do sort of agree with you;) I kinda like it. Just my 2pence. Go on then, I'll swap:d Quote Link to comment Share on other sites More sharing options...
Kev.O Posted November 14, 2011 Share Posted November 14, 2011 Great work as always Paul. Quote Link to comment Share on other sites More sharing options...
alex2jz Posted November 14, 2011 Share Posted November 14, 2011 Subscribed. Engine looks fantastic. Can't wait to see the car up and running. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 14, 2011 Share Posted November 14, 2011 that looks nice dude . the boostlogic manifold is the tits. i was looking at one on another na-t a few days back and the location and angle it sits the turbo at is perfect . ill be getting one of these next Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 14, 2011 Author Share Posted November 14, 2011 that looks nice dude . the boostlogic manifold is the tits. i was looking at one on another na-t a few days back and the location and angle it sits the turbo at is perfect . ill be getting one of these next Yeah I believe it's angled so there's no need to replace the dizzy cap which looks ok on mine, a good 30mm gap with out the leads fitted and thats using a 4'' intake. I've ordered all my oil line fittings etc so thats next on the list to fit Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 14, 2011 Author Share Posted November 14, 2011 Great work as always Paul. Thanks Kev, I hold you fully responsible for this though;) Quote Link to comment Share on other sites More sharing options...
pjavon Posted November 14, 2011 Author Share Posted November 14, 2011 Welded the oil feed 'tee' today and all my fittings and oil line have been dispatched:) Quote Link to comment Share on other sites More sharing options...
Hammer Posted November 14, 2011 Share Posted November 14, 2011 Tidy work mate. Looks really nice and clean. Will follow this with interest. Quote Link to comment Share on other sites More sharing options...
