Checking turbo oil seals.
hodge
Hi guys
Is there any way of doing this without stripping the turbo down.
Whilst the car is off the road I want to check everything and replace a few things. Im getting a slight pull of blue smoke on lift off (come off throttle) and just would like to explore every avenue. It's not a great deal but I know it's there.
Cheers
John
It would need stripping to check it John.
Thought as much Chris.
If you have the turbo off look for any signs of wetness in the turbine area. I had a leaky stock turbo on a 1JZ once and the exhaust housing was damp with oil.
I'll check once I pull the turbo off.
