Mrsupras Posted November 11, 2011 Share Posted November 11, 2011 hey guys,as i was drive my supra the Crankshaft Pulley take off,it's better to buy the same from the factory or is better to buy Lightweight Crank Pulley?if it's better the Lightweight Crank Pulley do i have to change the belt's and other stuff? thnx stavros. Quote Link to comment Share on other sites More sharing options...
Abz Posted November 11, 2011 Share Posted November 11, 2011 I'd recommend a stock replacement due to it being dampened. Whifbitz do one too. http://whifbitzperformancetuning.co.uk/toyota-supra-supra-engine-components-camshafts-pulleys-belts-garage-whifbitz-p-5968.html Quote Link to comment Share on other sites More sharing options...
Mrsupras Posted November 12, 2011 Author Share Posted November 12, 2011 I'd recommend a stock replacement due to it being dampened. Whifbitz do one too. http://whifbitzperformancetuning.co.uk/toyota-supra-supra-engine-components-camshafts-pulleys-belts-garage-whifbitz-p-5968.html thank you man,i found one used for 100 euros and i might go for it. cheers. Quote Link to comment Share on other sites More sharing options...
Abz Posted November 12, 2011 Share Posted November 12, 2011 thank you man,i found one used for 100 euros and i might go for it. cheers. No worries Make sure it is in good condition & off a low mileage car or as new as possible. If you can then go new, this is a major fail part on the Supra & over time & age they fail. Quote Link to comment Share on other sites More sharing options...
fastnfurious Posted November 12, 2011 Share Posted November 12, 2011 same thing happened on my Supra last year while cruising at 180km/h and finally got it sorted out with a brand new stock replacement unit, did the timing belt and oil seals servicing at the same time including replacing the old water pump unit (only changed the front portion as brand new unit comes with complete assembly). Quote Link to comment Share on other sites More sharing options...
