can you remove the wastagate VSV completly if have a electronic boost controler?
Lude
i am in the process of removing the turbo pipes the give a clean and paint.
was thinking of removing the wastagate VSV completely (as pictured here...)
as most of the pipes that come off it are blanked off now.
can i do this?
does this pipe go to it though? (thin one next to the letter 3) my cars away up my garage at the moment....
or does that pipe go somewhere else or can that be blanked off too?
Edited by Lude (see edit history)
mate when taking things off that you know nothing about you should always mark up where they come from, dots of tipex work well. also in the first picture it clearly indicates where the pipes belong.
you cant see where it connects to in the pic, may have gone to the turbo pipes,
yea when removing pipes i usually put masking tape around the pipe, with a number on (and do same other end)
