Hellstrom Posted November 10, 2011 Share Posted November 10, 2011 Is any identification marks on euro turbos as i might have a set to buy as id rather want euro turbos instead of the J-spec ones. the seller don't really know. Quote Link to comment Share on other sites More sharing options...
Stephen G Posted November 10, 2011 Share Posted November 10, 2011 The bolt pattern is different were they attach to the manifold iirc Quote Link to comment Share on other sites More sharing options...
Guigsy Posted November 10, 2011 Share Posted November 10, 2011 They have different bolt patterns don't they? Not sure you can put uks on a spec car without a uk ecu and injectors etc can you? Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted November 10, 2011 Author Share Posted November 10, 2011 strange... well can someone confirm you cant put euro turbos on jspec cylinder head and get em to work with standard ecu Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 10, 2011 Share Posted November 10, 2011 You need the euro spec manifolds as well, the J spec turbos have a 3 bolt flange whilst UKs have a 4 bolt flange. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted November 10, 2011 Author Share Posted November 10, 2011 (edited) That is np as i seem to be able to get a full set but np with stock ECU then? more like is there any additional sensor/VSV etc. --- I am here: http://maps.google.com/maps?ll=57.729138,11.786202 Edited November 10, 2011 by Hellstrom (see edit history) Quote Link to comment Share on other sites More sharing options...
Mario Posted November 10, 2011 Share Posted November 10, 2011 For identification i would measure the internal wastegate, i assume if the seller wants to sale them the turbos are alreadily taken from the car, i know the internal wastegate of the j-spec turbos is smaller in diameter then the euro-spec/uk-spec/us-spec. I will search for the wastegate diameter on both of the as i cant remeber it at the moment but will come back with the diameters. But why not get a set of j-spec turbochargers and get them hybrid made. No installation issues. http://www.mkivsupra.net/vbb/showthread.php?156897-Are-94-Stock-J-spec-Twin-Turbos-Ball-bearing http://www.supraforums.com/forum/showthread.php?624130-JDM-USDM-Turbo-manifold-and-OBD1-ECU-questions Quote Link to comment Share on other sites More sharing options...
Guigsy Posted November 10, 2011 Share Posted November 10, 2011 But why not get a set of j-spec turbochargers and get them hybrid made. No installation issues. I dont think anyoone on here has had any real sucess with hybryds. most seem to fail after 20k or so. Quote Link to comment Share on other sites More sharing options...
Mario Posted November 10, 2011 Share Posted November 10, 2011 Ok didn't knew that Guigsy. But for identification us spec turbos wastegate = 30mm J spec turbos smaller then 30mm. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted November 10, 2011 Author Share Posted November 10, 2011 i would try to hybrid the Euro turbos, its more for a project as for now iam just rebuilding the engine. I just want to keep the stock look the early spool and maybe get about 450-500hk in the future. Iam not doing this at this point as i want to take 1 thing at the time. also the costs for going above 400hk is going to cost some. Future plan is to get Higher lift cam with more duration. Fuel/timing controll Euro turbos with bigger wheels That why i asked more or less. anyways if the euro has 4bolts/turbo to manifold thats enough to judge wether its a euro or not thanks for the information lads! Cheers Quote Link to comment Share on other sites More sharing options...
Scott Posted November 10, 2011 Share Posted November 10, 2011 No worries with the ECU etc. You an just throw on the tubbys (as mentioned manifold & dpipe/cat are required) and be done with it. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted November 17, 2011 Author Share Posted November 17, 2011 Iam going to bump this thread as iam most likely going to buy a set of euro turbos. My question is. does the J-spec have 3bolts/turbo? and euro have 4 bolts per turbo. can anyone confirm that this is a rule and cant be mixed up with VVTI turbos or what not. the setup iam going to buy have 4bolts/turbo. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 17, 2011 Share Posted November 17, 2011 It's a rule, and VVTi 2JZ-GTE engines also have 3 stud pattern turbine housings. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted November 17, 2011 Author Share Posted November 17, 2011 Awsome info Chris! i would like to pick your brain tbh! great knowledge! Cheers Quote Link to comment Share on other sites More sharing options...
