Basic maths? Think you know?
caseys
  • Replies 74
This all stems from an argument about it with a bunch of programmers. There are several ways to read this and also execute it!
Doesn't the generally-accepted operator precedence define a single correct way though? I suppose then it's an issue of whether one follows the generally-accepted way.
Hmmm I voted 0 but now I think it's 15. The way it's written with a space at the end for the zero kind of implies that the whole thing is multiplied by 0 at the end (like (5+5+5-5+5+5-5)0 ) but if you write it all with the same spaces it's 5+5+5-5+5+5-5+5x0 which is the same as karolina's post (although there are added brackets they don't make a difference to the outcome here) given that you have to do multiplication before addition and subtraction (bodmas). Those are my thoughts :)
I voted 15, but I was probably wrong!
I don't know what the answer actually is, because it would depend on the order you carry out the subtractions.
5+5+5-5+5+5-5+5x0
BODMAS says you should do the multiplication first
5+5+5-5+5+5-5+0
Then you should do the addition
15-15-5
but there is no convention to the order of subtractions.
so the answer could be either 0-5 = -5 or 15-10 = 5
Interesting - and I hate you for proving my inadequacies.
Mike
