Mugello Posted May 7, 2012 Share Posted May 7, 2012 Looks like you found your problem I had a quick look this morning and i coudnt get to them easily and didnt have the time to remove the inlet (now back at university ) Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 7, 2012 Share Posted May 7, 2012 Also mate, was it just 4mm vac hose ? (need to order some) I know some of it is 5mm and 7mm....... Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 7, 2012 Share Posted May 7, 2012 i used 4mm that i had already and worked fine. put some small zip ties on every joint i could find. car runs better than ever now. good luck!! Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 7, 2012 Share Posted May 7, 2012 i used 4mm that i had already and worked fine. put some small zip ties on every joint i could find. car runs better than ever now. good luck!! Good Glad you sorted it mate. I will attempt mine when i get back from uni Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 7, 2012 Author Share Posted May 7, 2012 Well I stripped all the turbo side down , started to replace all the pipes... Then I found this at the back of the actuator Split pipe which Im hoping I did not cause by pulling the pipe off Just gone for a burn ........... NO LUCK Inlet next but I'm going to wait untill Japfest has gone...bloody tired and peed off now Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted May 7, 2012 Share Posted May 7, 2012 Did it blow out Air when removing the pressure hoose to the iacv vsv? Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 7, 2012 Author Share Posted May 7, 2012 Did it blow out Air when removing the pressure hoose to the iacv vsv? I forgot to check .. Was so hacked off it was not that I just shut the garage and went in lol I will try later though Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 7, 2012 Share Posted May 7, 2012 Did it blow out Air when removing the pressure hoose to the iacv vsv? Mine didnt So simple fix i hope mplavery - Another split hose fixed, hope you sort it out ! Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 7, 2012 Author Share Posted May 7, 2012 Did it blow out Air when removing the pressure hoose to the iacv vsv? Just been out in it again.. Pressure comes out when I pull the pipe from the hard pipe to the IACV No pressure from the actuator to the IACV which I'm guessing is right Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted May 7, 2012 Share Posted May 7, 2012 Thats correct. Check egcv to make sure that vsv dont play up Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 7, 2012 Author Share Posted May 7, 2012 Thats correct. Check egcv to make sure that vsv dont play up I did check straight after I switched of then engine So does it seem that I have no split pipes any more I have pulled one of the pipes of the EGVC which has pressure?.. What else can I check to make sure it's ok Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 8, 2012 Share Posted May 8, 2012 These were the 2 hoses on mine that split: Borrowed mplavery's photo: The tops of the hoses as seen in the picture were fine, but the other end where they join an actuator and electronic valve were both split. Quote Link to comment Share on other sites More sharing options...
Sukhy Posted May 8, 2012 Share Posted May 8, 2012 These were the 2 hoses on mine that split: Borrowed mplavery's photo: http://i4.photobucket.com/albums/y112/mplavery/9910cb19.jpg The tops of the hoses as seen in the picture were fine, but the other end where they join an actuator and electronic valve were both split. Great thread. I too have been having issues with the second turbo coming online and hit a hesitation around 3800rpm. Sometimes the 2nd turbo wont come on, and other times it will. If I downshift to around 4500rpm and floor it, there's no 2nd turbo. But if I let off and then plant it again it pulls to hard with both turbos to redline. When I pulled the pipe off the IACV vsv i had some air pressure released so guess thats fine. I then found a split in the same pipe as pictured above (left one) on the vsv side. I repaired it and went for a drive. The hesitation is not a strong now but its still there. Pretty much the same symptoms as mentioned before. This is at 1 bar boost. At 1.2 it does not reach the desired boost level so im guessing there is another leak somewhere which im on the hunt for. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 8, 2012 Share Posted May 8, 2012 I replaced as many hoses as I could and zip tied them all nice and tight as well. Even if the hoses looked ok they were replaced. Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 8, 2012 Author Share Posted May 8, 2012 Great thread. I too have been having issues with the second turbo coming online and hit a hesitation around 3800rpm. Sometimes the 2nd turbo wont come on, and other times it will. If I downshift to around 4500rpm and floor it, there's no 2nd turbo. But if I let off and then plant it again it pulls to hard with both turbos to redline. When I pulled the pipe off the IACV vsv i had some air pressure released so guess thats fine. I then found a split in the same pipe as pictured above (left one) on the vsv side. I repaired it and went for a drive. The hesitation is not a strong now but its still there. Pretty much the same symptoms as mentioned before. This is at 1 bar boost. At 1.2 it does not reach the desired boost level so im guessing there is another leak somewhere which im on the hunt for. Its a nightmare mate. I have replaced most hoses and still have a issue...I still have a few more ideas though if that does not work im sending the car to SRD as its getting me down now... Im going to do a wheel bearing tonight and have another look If you find out what your problem is, post some pics up to help other mate.... Quote Link to comment Share on other sites More sharing options...
Sukhy Posted May 8, 2012 Share Posted May 8, 2012 Will do mate. Ive just spent the best part of the afternoon looking for split pipes and cant find any others at the moment. This is with everything still in place and me just trying to access all the pipes as possible. There is one that I can just about see underneath the turbos that goes from the vsv to the actuator which I suspect could be the problem. The pipe looks a little tired but ok from the side I can see. Mine is going to Jurgen at the end of the month so if I dont succeed then I'm having Jurgen look at it. On a side note, where are you guys getting your replacement hoses/pipes from? Its a bit of a nightmare trying to find somewhere locally that does the same size. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted May 8, 2012 Share Posted May 8, 2012 I had loads left over from my previous cars, however have a look in the sale section, Nodalmighty is selling a load of Samco ones that would be perfect! Other than that I get mine from ebay. One of my split hoses was to the actuator you mentioned in your post. I removed all the air intake stuff for a better look, easy to get to that way. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 8, 2012 Share Posted May 8, 2012 Me and my dad are having problems with no boost on 1st turbo, Some days it will boost and others it wont its weird. Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 8, 2012 Share Posted May 8, 2012 Me and my dad are having problems with no boost on 1st turbo, Some days it will boost and others it wont its weird. Id say check all hoses.... I have a problem with the second turbo, but after swapping 99% of the hoses on the turbo side, turbo 1 feels stronger !! (i did find some old leaky hoses) Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 8, 2012 Share Posted May 8, 2012 Okay i will do that Cheers mate. Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 8, 2012 Share Posted May 8, 2012 Okay i will do that Cheers mate. Good luck fella I will hopefully sort my 2nd turbo this weekend. Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 8, 2012 Author Share Posted May 8, 2012 Id say check all hoses.... I have a problem with the second turbo, but after swapping 99% of the hoses on the turbo side, turbo 1 feels stronger !! (i did find some old leaky hoses) Same here I think I have replaced at least 3 slightly split hoses and now number one is sharper at pulling... I have tested the actuators making sure the open etc etc I have even checked the pressure when driving and I do get a rich of pressure when the second turbo kicks in but on my boost gauge its not getting any higher then 0.5 bar Also checked the air compressor pipes which were fine which is much easier from underneath by the way...especially if you have a ramp Really running out of ideas now.... Looks like a trip to SRD'S Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 8, 2012 Share Posted May 8, 2012 Same here I think I have replaced at least 3 slightly split hoses and now number one is sharper at pulling... I have tested the actuators making sure the open etc etc I have even checked the pressure when driving and I do get a rich of pressure when the second turbo kicks in but on my boost gauge its not getting any higher then 0.5 bar Also checked the air compressor pipes which were fine which is much easier from underneath by the way...especially if you have a ramp Really running out of ideas now.... Looks like a trip to SRD'S Best give it to and expert like SRD or Whifbitz etc - Yes you may pay to dollar but atleast the problem will be fixed Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 8, 2012 Share Posted May 8, 2012 Don't standard turbos boost to 0.7 bar as standard? Quote Link to comment Share on other sites More sharing options...
mplavery Posted May 8, 2012 Author Share Posted May 8, 2012 Best give it to and expert like SRD or Whifbitz etc - Yes you may pay to dollar but atleast the problem will be fixed Looks like it.. I enjoy doing stuff my self but it's I'm getting out of my depth now and just want it working Quote Link to comment Share on other sites More sharing options...
